simpleFoam error while running the simulation
Old   August 12, 2015, 13:58
Angry simpleFoam error while running the simulation
Honey
ansab is on a distinguished road
Hey guys I am new to OpenFoam,
As for my project , I have to simulate an external flow around an airfoil. I did all the steps and successfully create the mesh using snappyHexMesh. I intend to use K-Epsilon model and setup the files according to it. But when I am running simpleFoam command, I am getting this error.
Build : 2.3.1-bcfaaa7b8660
Exec : simpleFoam
Date : Aug 12 2015
Time : 19:36:36
Host : "ka-pc5l"
PID : 9605
Case : /home/kalabor/tutorials/mesh/snappyHexMesh/goe532-airfoil-testsimulation
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading field p
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/kalabor/tutorials/mesh/snappyHexMesh/goe532-airfoil-testsimulation/0/p at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
I am stuck here for 2 weeks now. Please help me. Thanks in advance.
Ansab
ansab is offline   Reply With Quote
Old   August 12, 2015, 14:04
anonymous
ssss is on a distinguished road
Seriously? Two weeks? The error tells you exactly what is failing, there is no p file in the 0 folder.
Go to the tutorials/incompressible/simpleFoam and look how the test case is configured
ssss is offline   Reply With Quote
Old   August 12, 2015, 17:09
Retired Super Moderator
Bruno Santos
@ansab: Quick suggestion: Study chapter 2 of the OpenFOAM User Guide: http://cfd.direct/openfoam/user-guide/tutorials/ - because the reported problem is first explained in subsection "2.1.1.2 Boundary and initial conditions"
Old   August 13, 2015, 02:51
Honey
Dear ssss, the problem is that I do have p file in 0 folder along with all the necessary files required to run the simulation
Old   August 13, 2015, 03:35
anonymous
Okey then upload the case and I will have a look at it (don't upload the polymesh folder because I imagine that it will weight a lot)
Old   August 13, 2015, 06:46
Honey
Dear ssss, thanks for the reply but I am now successful in running the simulation. The problem as suggested by Bruno, was in the BOUNDARY FIELDS in P, U, K ,Epsilon and Nut files.
Crashed user libraries due to compiling them while running a simulation juhuettn OpenFOAM Programming & Development 1 June 3, 2015 09:22
Having problems running transient fluent simulation in batch mode obylong FLUENT 1 August 14, 2014 23:58
SimpleFoam convergence problem with really simple simulation mayank.dce2k7 OpenFOAM Running, Solving & CFD 2 November 19, 2013 05:28
Replacing mesh while running a simulation akultane CFX 1 November 15, 2009 13:46
What do you CFD guys do during a long simulation running? bearcat Main CFD Forum 5 July 23, 2009 08:08
