June 23, 2014, 11:18 |
Running snappyHexMesh with interDyMFoam
Rep Power: 11 |
Hi everybody,
I am trying to run snappyHexMesh with interDyMFoam, but it seems I have a probleme. I explain what I am doing : I took the floatingObject tutorials. I want to replace the floatingObject by an other geometry using a stl file and snappyHexMesh. Finally, I have no problem with the snappyHexMesh (it runs well), but I have a probleme with interDyMFoam. The errors are the following errors : #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 at sigaction.c:? #3 void Foam::MULES::limiter<Foam::geometricOneField, Foam::zeroField, Foam::zeroField>(Foam::Field<double>&, Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::zeroField const&, Foam::zeroField const&, double, double, int) at ??:? #4 at MULES.C:? #5 Foam::MULES::explicitSolve(Foam::GeometricField<do uble, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, double, double) at ??:? #6 at ??:? #7 __libc_start_main at ??:? #8 at ??:? Someone could help me to solve this ? Thanks in advance. Kind regards, Louise |
License trouble: ANSLIC_ADMIN, FLEXlm not running, but two lmgrd processes running! | dancoz87 | ANSYS | 17 | November 14, 2016 01:10 |
parallel error with cyclic BCs for pimpleDyMFoam and trouble in resuming running | sunliming | OpenFOAM Bugs | 21 | November 22, 2013 03:38 |
Segmentation fault running waveDyMFoam solver (mod. interDyMFoam solver - waves2Foam) | Ed R | OpenFOAM Running, Solving & CFD | 5 | July 2, 2013 11:36 |
Strange Results With snappyHexMesh | calebamiles | OpenFOAM Running, Solving & CFD | 0 | August 14, 2011 16:02 |
What do you CFD guys do during a long simulation running? | bearcat | Main CFD Forum | 5 | July 23, 2009 08:08 |
