LES-Content of a Detached Eddy Simulation for OpenFOAM
Like Tree9Likes
Old   July 3, 2012, 11:36
Default LES-Content of a Detached Eddy Simulation for OpenFOAM
Anne Gerdes
Anne Lincke is on a distinguished road
Hey Foamers,
I started with OpenFOAMŪ+DES, SpalartAllmarasIDDES.
I would like to determine the LES-Content of my computation.
Does someone know an indicator or a way to determine the content?
It would be desirable to see the averaged LES content...
Thanks
Anne
Anne Lincke is offline   Reply With Quote
Old   July 4, 2012, 11:07
Vesselin Krastev
vkrastev is on a distinguished road
Originally Posted by Anne Lincke View Post
Hey Foamers,
Thanks
Anne
you can obtain the averaged resolved Reynolds stresses by just activating the averaging function for the velocity field at the end of your controlDict:
functions
fieldAverage
type fieldAverage;
functionObjectLibs ("libfieldFunctionObjects.so");
enabled true;
outputControl outputTime;
fields
U
mean on;
prime2Mean on;
base time;
The above addition will produce and write both the time-averaged velocity field as well as the six time averaged components of the resolved Reynolds stresses tensor (this is the meaning of prime2Mean: fluctuating components squared and averaged against time). Of course, to obtain reliable results, you have to start averaging when the flow has developed its transient content and then average for a sufficiently long period, in order to get the mean (and thus the fluctuating) values stabilized.
Hope this helps
V.
vonboett likes this.
vkrastev is offline   Reply With Quote
Old   July 5, 2012, 03:11
Anne Gerdes
Hey Vesselin,
thanks for your answer. I already activated fieldAverage and plottet those values.
But this was not my question, maybe I expressed in a bad way.
What I meant: I would like to plot a "sensor" which is for example "1" in regions where LES-mode is activated and "0" in regions where RANS-mode is activated.
When outputting the averaged sensor, one could see the regions where mainly LES-, and regions where mainly RANS-mode was activated.
It is desirable for a DES to switch on RANS-mode in near-wall regions and LES-mode inside the fluid volume.
Dou you or someone else have an idea how to solve this in OpenFOAM?
I heard that it is common for solvers to have such a sensor implemented....
Thanks
Anne
Old   July 5, 2012, 04:10
Vesselin Krastev
Hey Vesselin,
Thanks
Anne
Ok, so I haven't understood your question properly...Well, if you are interested in a post-processing of this RANS/LES parameter than the easiest way should be to write your own post-proc utility which calculates and writes the parameter using already calculated flow variables. For the DES and DDES models actually all you have to do is to calculate the ratio between the RANS and LES lenght scales which are used to discriminate where to apply the RANS or DES formulation (where the RANS scale is smaller then the LES one the model works in RANS mode, the opposite applies for the LES mode). I'm not sure if things are that easy with the IDDES model, which as far as I know has a much more complex formulation. Just as an example, I can send you an utility which calculates and writes the delaying function fd included in the DDES model.
Good luck for your work
V.
David* likes this.
Old   July 17, 2012, 04:24
Anne Gerdes
Hey Vesselin,
sorry for the late reply.
Thanks a lot for this tool. I wrote a similar one for IDDES.
Kind Regards
Anne
Old   July 17, 2012, 04:35
Vesselin Krastev
Hi Anne,
no problem, happy to see that you have solved your issue!
Regards
V.
Old   August 8, 2012, 05:35
Lukas
luhawk is on a distinguished road
Hello everybody,
hello Anne,
I am currently trying to work my way into DES in OpenFOAM. Such a tool as you said would really be neat to have. Unfortunately, when it comes to coding in OpenFOAM, I am pretty much a novice, so I have a question:
Did you implement the evaluation of the length scales as a post processing or routine did you modify the turbulence model to write a field?
Any help is appreciated.
Best regards,
Lukas
luhawk is offline   Reply With Quote
Old   August 8, 2012, 05:52
Anne Gerdes
Hey Lukas,
I implemented a postprocessing tool which writes \tilde{fd}*(1+fe) and 1-\tilde{fd} which are the coefficients of l_RANS and l_LES, respectively (according to the paper of Shur et. al).
It would be desirable to insert such a tool inside a simulation such that these coefficients are computed at each time step and could be averaged.
But I only succeeded in doing this inside a postprocessing routine, which computes these values for the written time steps. So one can see the LES content of each time step which was output.
Kind Regards
Anne
potentialFoam likes this.
Old   August 9, 2012, 00:15
Jason Eason
JulytoNovember is on a distinguished road
Hi Anne,
Could you please post your LESProperties file, with SpalartAllmarasIDDES implemented?
Debian Squeeze - OpenFOAM-2.1.x, Paraview-3.12.0
JulytoNovember is offline   Reply With Quote
Old   August 9, 2012, 02:55
Timo K.
timo_IHS is on a distinguished road
Hi Anne,
have a look in the extend project.
You have to define an IOobject.
timo_IHS is offline   Reply With Quote
Old   August 9, 2012, 03:09
Anne Gerdes
Hey,
Originally Posted by JulytoNovember View Post
Hi Anne,
here it is:
HTML Code:
|  \\    /   O peration     | Version:  1.7.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      LESProperties;
LESModel       SpalartAllmarasIDDES;
printCoeffs     on;
delta IDDESDelta; // maxDeltaxyz;//
maxDeltaxyzCoeffs
    deltaCoeff 2;
SpalartAllmarasIDDESCoeffs
    fieldMaps
        nuTilda         nuTilda;
        nuSgs           nuSgs;
    alphaNut        1.5;
    Cb1             0.1355;
    Cb2             0.622;
    Cw2             0.3;
    Cw3             2;
    Cv1             7.1;
    Cv2             5;
    CDES            0.65;
    ck              0.07;
    fwStar          0.424;
    cl              3.55;
    ct              1.63;
IDDESDeltaCoeffs
    cw 0.15;
    deltaCoeff      2;//1; 2 for hexMesh
SpalartAllmarasCoeffs
    alphaNut         1.5;
    Cb1              0.1355;
    Cb2              0.622;
    Cw2              0.3;
    Cw3              2;
    Cv1              7.1;
    Cv2              5.0;
    CDES             0.65;
    ck               0.07;
SpalartAllmarasDDESCoeffs
    alphaNut         1.5;
    Cb1              0.1355;
    Cb2              0.622;
    Cw2              0.3;
    Cw3              2.0;
    Cv1              7.1;
    Cv2              5.0;
    CDES             0.65;
    ck               0.07;
    alphaNut         1.5;
    kappa            0.4187;
    Cb1              0.1355;
    Cb2              0.622;
    Cw2              0.3;
    Cw3              2.0;
    Cv1              7.1;
    Cv2              5.0;
    CDES             0.65;
    ck               0.07;
PrandtlCoeffs
    delta           cubeRootVol;
    cubeRootVolCoeffs
        deltaCoeff      1;
    smoothCoeffs
        delta           cubeRootVol;
        cubeRootVolCoeffs
            deltaCoeff      1;
        maxDeltaRatio   1.1;
    Cdelta          0.158;
vanDriestCoeffs
    delta           cubeRootVol;
    cubeRootVolCoeffs
        deltaCoeff      1;
    smoothCoeffs
        delta           cubeRootVol;
        cubeRootVolCoeffs
            deltaCoeff      1;
        maxDeltaRatio   1.1;
    Aplus           26;
    Cdelta          0.158;
smoothCoeffs
    delta           cubeRootVol;
    cubeRootVolCoeffs
        deltaCoeff      1;
    maxDeltaRatio   1.1;
Kind Regards,
Anne
cheng1988sjtu and Alexee like this.
Old   August 14, 2012, 09:21
Jane L
Jane L is on a distinguished road
just in case you're still interested. You can define the IOobject Timo_IHS mentioned in your own copy of the SpalartAllmaras.C (DES) model which could look like this:
  RANSregion_
        IOobject
            "RANSregion",
            runTime_.timeName(),
            mesh_,
            IOobject::MUST_READ,
            IOobject::AUTO_WRITE
        mesh_
"RANSregion_" has to be initialized in the *.H file and you need a RANSregion_ file in the 0 folder with the correct dimensions depending on your equation to calculate "RANSregion_". The equation itself may be placed where nuSgs is calculated. Example for SpalartAllmaras:
void mySpalartAllmaras::updateSubGridScaleFields()
    nuSgs_.internalField() = fv1()*nuTilda_.internalField();
    nuSgs_.correctBoundaryConditions();
    RANSregion_ = CDES_*delta() - y_;
This gives you a positive result in the area where RANS is used and a negative where LES is used.
kind regards
Jane L is offline   Reply With Quote
Old   August 14, 2012, 12:56
Awais Ali
owayz is on a distinguished road
Send a message via MSN to owayz
Hi Jane L,
Can we do something similar for other Turbulence models as well. And what is "fv1()" in the above equation. It would be very helpful if you could explain shortly what this code snippet is actually doing.
Regards,
Awais
owayz is offline   Reply With Quote
Old   August 15, 2012, 02:22
Jane L
Hi!
The example above is a possible solution for the issue Anne described:
While this makes only sence in a DES method, you can of course apply something similar to any turbulence model if you wish to have some more outputdata. This data will be written in the folder of each timestep and can be used by paraview.
This code snipped is a variation of the SpalartAllmaras turbulence model, which is located in your OpenFOAM installation folder under:
/src/turbulenceModels/incompressible/LES/SpalartAllmaras/SpalartAllmaras.C
So actually the function "fv1()" comes from this model. In order to alter existing turbulence models you should make your own copy of that turbulence model. Follow the instructions of Hakan Nilsson (you find the "implementTurbulenceModel.pdf" via google)
I hope this helps!
regards
Old   August 15, 2012, 10:17
Anne Gerdes
Hey Jane,
thank you very much for this information. I am still interested in implementing such a sensor and will try to do it in this way.
Starting with Spalart-Allmaras and DES seems to be a good way, as the model gets more and more complex for DDES and IDDES.
Kind Regards
Anne
Old   August 15, 2012, 11:11
Awais Ali
Hi Jane,
Thanks for your reply. I will try to look into that pdf. Also I might try to do something similar for LES as well.
Regards,
Awais
Old   August 17, 2012, 00:29
Tarak
Tarak is on a distinguished road
Hii,
Have you tried plotting the energy spectrum to get an estimate of the LES content?
Tarak is offline   Reply With Quote
Old   March 1, 2013, 15:22
MaryBau is on a distinguished road
Hi;
I have been trying to run a simulation in OFv2.1.0 with SpalartAllmarasIDDES using exactly the same LESProperties file that Anne L. posted in this forum. However, I am getting this error:
Selecting incompressible transport model Newtonian
Selecting turbulence model type LESModel
Selecting LES turbulence model SpalartAllmarasIDDES
--> FOAM FATAL IO ERROR:
keyword delta is undefined in dictionary ""
file:
    From function dictionary::lookupEntry(const word&, bool, bool) const
    in file db/dictionary/dictionary.C at line 400.
FOAM exiting
The IDDESDelta is recognized, because if I spell it wrong it appears on the LESdelta types.
--> FOAM FATAL ERROR:
Unknown LESdelta type XXIDDESDelta
Valid LESdelta types are :
6
IDDESDelta
Prandtl
cubeRootVol
maxDeltaxyz
smooth
vanDriest
    From function LESdelta::New(const fvMesh&, const dictionary&)
    in file LESdelta/LESdelta.C at line 78.
FOAM exiting
Any ideas or suggestions?
Thanks!
MaryBau is offline   Reply With Quote
Old   March 4, 2013, 03:27
Anne Gerdes
Hey,
I installed OpenFOAM-2.1.1. and since then I get exactly the same error message. I would be really interested in how to solve this, too.
Old   March 6, 2013, 08:16
My Name
ingcorra is on a distinguished road
This should be the correct LESProperties file for 2.1.x
|  \\    /   O peration     | Version:  1.7.1                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
printCoeffs     on;
delta cubeRootVol;
printCoeffs on;
cubeRootVolCoeffs
    deltaCoeff      1;
    delta IDDESDelta;
    IDDESDeltaCoeffs
        deltaCoeff 1;
        cw 0.15;
ingcorra is offline   Reply With Quote
Detached eddy simulation rooholghodos OpenFOAM 0 March 7, 2012 10:35
Transition RANS to LES during simulation LorenzN OpenFOAM Running, Solving & CFD 4 November 17, 2011 10:47
Link between eddy viscosity and subgrid-scale turbulent viscosity in LES Marvin Main CFD Forum 6 December 4, 2009 11:08
Large Eddy Simulation help PattiMichelle Phoenics 2 April 29, 2005 13:24
Detached Eddy Simulation Fred Main CFD Forum 4 December 16, 2000 09:45
