July 9, 2014, 12:13 |
Forced convective evaporation
Sreeyuth
Rep Power: 11 |
Hello everyone!
Allow me to get straight to the point. I have two domains on top of each other. The top domain has air flow in it. The bottom domain is a solid which has pores open to the domain above (it is a mesh obtained directly from CT scans). But since some of the pores run across the entire height of the bottom domain, we have air penetration in the bottom domain too. Up to now, I have managed to simulate this much with simpleFoam. Now I want to introduce water into the solid domain and then try to analyze how the solid dries due to the air flow above (forced convective evaporation). I am not specifically interested in tracking the waterfront. My parameters of interest would be the heat and mass fluxes at the air/solid interface. Can anyone please suggest which solvers to combine, if any? At the moment, what comes to my mind is simpleFoam+conjugateHeatFoam+interPhaseChangeFoam. |
July 10, 2014, 02:34 |
matej forman
interPhaseChangeFoam seems to be good start. You may look here http://www.tfd.chalmers.se/~hani/kur...ChangeFoam.pdf not to reinvent the weel. You will probably also need to tweak the liquid in the porous region modelling. matej |
February 16, 2018, 10:37 |
Enrico
Rep Power: 10 |
Hi everyone,
I'm trying to solve a similar problem. I am modeling the pipeline drying with dry air, there is a water pool with height of 20 mm in the lower part of the pipe, and I want to simulate the evaporation due to the air forced convection. Any suggestions? Thanks, Alessio |
Water Surface Evaporation | sunggun1212 | FLUENT | 3 | January 11, 2020 04:12 |
Forced convective evaporation | sreeyuth | Main CFD Forum | 0 | July 9, 2014 12:06 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
Coupled vs Seg - Natural vs. Forced Convection | Alex | Siemens | 5 | December 12, 2007 04:58 |
Forced Convective Heat Transfer for moving cylinde | Guest | Main CFD Forum | 3 | October 11, 2005 14:43 |
