Sample not working correctly
Old   July 3, 2014, 23:38
Default Sample not working correctly
starter
sihaqqi is on a distinguished road
Hi
I am trying to compare velocity profile data from two meshes. My geometry is two pipes connected at 90 degrees to each other via a mitered sharp bend. My sampleDict below, I am getting error given below sample dict. Can someone possible identify the reason for the error. I have tried to remove surface part as well as I only want to have velocity vector values on the sample lines drawn in folder sets. I shall be very grateful for support.
Regards
SAMPLEDICT
| \\ / O peration | Version: 2.1.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object sampleDict;
setFormat raw;
surfaceFormat raw;
formatOptions
ensight
format ascii;
interpolationScheme cellPoint;
// Fields to sample.
fields
U
sets
set1
type uniform;
axis xyz;
start (0.1000 2.72748 0.00000);
end (0.1000 2.80000 0.00000);
nPoints 200;
set2
type uniform;
axis xyz;
start (0.3000 2.72748 0.00000);
end (0.3000 2.80000 0.00000);
nPoints 200;
set3
type uniform;
axis xyz;
start (0.5000 2.72748 0.00000);
end (0.5000 2.80000 0.00000);
nPoints 200;
set4
type uniform;
axis xyz;
start (1.0000 2.72748 0.00000);
end (1.0000 2.80000 0.00000);
nPoints 200;
set5
type uniform;
axis xyz;
start (1.5000 2.72748 0.00000);
end (1.5000 2.80000 0.00000);
nPoints 200;
set6
type uniform;
axis xyz;
start (2.0000 2.72748 0.00000);
end (2.0000 2.80000 0.00000);
nPoints 200;
set7
type uniform;
axis xyz;
start (2.5000 2.72748 0.00000);
end (2.5000 2.80000 0.00000);
nPoints 200;
set8
type uniform;
axis xyz;
start (3.0000 2.72748 0.00000);
end (3.0000 2.80000 0.00000);
nPoints 200;
set9
type uniform;
axis xyz;
start (3.5000 2.72748 0.00000);
end (3.5000 2.80000 0.00000);
nPoints 200;
set10
type uniform;
axis xyz;
start (4.0000 2.72748 0.00000);
end (4.0000 2.80000 0.00000);
nPoints 200;
set11
type uniform;
axis xyz;
start (4.5000 2.72748 0.00000);
end (4.5000 2.80000 0.00000);
nPoints 200;
set12
type uniform;
axis xyz;
start (0.003627 1.00000 0.00000);
end (-0.003627 1.00000 0.00000);
nPoints 200;
set13
type uniform;
axis xyz;
start (0.003627 1.50000 0.00000);
end (-0.003627 1.50000 0.00000);
nPoints 200;
set14
type uniform;
axis xyz;
start (0.003627 2.00000 0.00000);
end (-0.003627 2.00000 0.00000);
nPoints 200;
start (0.003627 2.50000 0.00000);
surfaces
wall
type patch;
patches ( );
ERROR
1]
[1]
[1] --> FOAM FATAL IO ERROR:
[1] keyword start is undefined in dictionary "/scratch/director674/shaqqi/elbow/e45/LES/final/24_test1_75/processor1/system/sampleDict::sets"
[1]
[1] file: /scratch/director674/shaqqi/elbow/e45/LES/final/24_test1_75/processor1/system/sampleDict::sets from line 0 to line 0.
[1]
[1] From function dictionary::lookupEntry(const word&, bool, bool) const
[1] in file db/dictionary/dictionary.C at line 400.
[1]
FOAM parallel run exiting
[1]
[3]
[3]
[3] --> FOAM FATAL IO ERROR:
[3] keyword start is undefined in dictionary "/scratch/director674/shaqqi/elbow/e45/LES/final/24_test1_75/processor3/system/sampleDict::sets"
[3]
[3] file: /scratch/director674/shaqqi/elbow/e45/LES/final/24_test1_75/processor3/system/sampleDict::sets from line 0 to line 0.
[3]
[3] From function dictionary::lookupEntry(const word&, bool, bool) const
[3] in file db/dictionary/dictionary.C at line 400.
[3]
[3]
[19]
[19]
[19] --> FOAM FATAL IO ERROR:
[19] keyword start is undefined in dictionary "/scratch/director674/shaqqi/elbow/e45/LES/final/24_test1_75/processor19/system/sampleDict::sets"
[19]
[17] [19]
file: [17] /scratch/director674/shaqqi/elbow/e45/LES/final/24_test1_75/processor19/system/sampleDict::sets from line
0 to line [17] 0.--> FOAM FATAL IO ERROR:
[17] [19] keyword start is undefined in dictionary "/scratch/director674/shaqqi/elbow/e45/LES/final/24_test1_75/processor17/system/sampleDict::sets"
[19] [17] From function
dictionary::lookupEntry(const word&, bool, bool) const[17]
file: [19] /scratch/director674/shaqqi/elbow/e45/LES/final/24_test1_75/processor17/system/sampleDict::sets in file from line db/dictionary/dictionary.C0 at line [15] 400 to line 0.
[15]
[19]
[17]
[15]
[19] --> FOAM FATAL IO ERROR: [17]
From function [15] keyword start is undefined in dictionary "/scratch/director674/shaqqi/elbow/e45/LES/final/24_test1_75/processor15/system/sampleDict::sets"
[15] dictionary::lookupEntry(const word&, bool, bool) const
[17] [15] in file file: db/dictionary/dictionary.C/scratch/director674/shaqqi/elbow/e45/LES/final/24_test1_75/processor15/system/sampleDict::sets at line from line 4000. to line
[17] 0
.[17]
[15]
[15] From function dictionary::lookupEntry(const word&, bool, bool) const
[15] in file db/dictionary/dictionary.C at line 400.
[15]
[15]
[21]
[21]
[21] --> FOAM FATAL IO ERROR:
[21] keyword start is undefined in dictionary "/scratch/director674/shaqqi/elbow/e45/LES/final/24_test1_75/processor21/system/sampleDict::sets"
[21]
[21] file: /scratch/director674/shaqqi/elbow/e45/LES/final/24_test1_75/processor21/system/sampleDict::sets from line 0 to line 0.
[21]
[21] From function dictionary::lookupEntry(const word&, bool, bool) const
[21] in file db/dictionary/dictionary.C at line 400.
[5] [21]
[21]
[13] keyword start is undefined in dictionary "/scratch/director674/shaqqi/elbow/e45/LES/final/24_test1_75/processor13/system/sampleDict::sets"[4]
and so forth
sihaqqi is offline   Reply With Quote
Old   July 12, 2014, 01:36
starter
problem resolved..coordinates were on boundary..reduced dimensions and done
sampledict, sets, velocity profile
Sample utility not working properly titio OpenFOAM 2 June 9, 2010 10:45
Simple plane sample not working marupio OpenFOAM Post-Processing 2 May 18, 2010 13:23
heat conducting in a solid domain Rogerio Fernandes Brito CFX 0 March 18, 2008 17:20
about my old post Rogerio Fernandes Brito CFX 1 February 8, 2008 19:19
CAE program for heat conducting Rogerio Fernandes Brito FLUENT 0 February 3, 2008 11:22
