Santiago Marquez Damian
Rep Power: 23 ![]() |
Hi all, is there any way to force FOAM to do a check point writing during a running?.
Sometimes I'm running big cases and want to know how the results are going. It would be nice to tell FOAM to do a writeNow but without stopping Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D. Research Scientist Research Center for Computational Methods (CIMEC) - CONICET/UNL Tel: 54-342-4511594 Int. 7032 Colectora Ruta Nac. 168 / Paraje El Pozo (3000) Santa Fe - Argentina. http://www.cimec.org.ar |
Joachim Herb
Rep Power: 21 ![]() |
Perhaps this is what you are looking for: In system/controlDict change the writeControl to timeStep and the writeInterval to 1. If runTimeModifiable is set to true this will write the results of the next time step/iteration to the disk. Then change the settings back to what they were before.
Yes, sometimes I do that, but it resets the counter for writing and you lose the original writing interval, i.e. if you were writing each 10 secs. and you ask to dump data at t=11, then when you go back to write every 10 secs. you will have dirs 21, 22, and so on.
Regards.
Retired Super Moderator
Bruno Santos
Rep Power: 128 ![]() ![]() ![]() ![]() ![]() ![]() |
Greetings to all!
There are a few possible solutions:
Bruno
An error has occurred when Writing backup file | tian | CFX | 0 | June 28, 2007 21:29 |
journal file command for writing mass flow rate | James | FLUENT | 0 | July 26, 2006 10:51 |
Tutorial is not running on star-CD version 3.2 | Arnab | Siemens | 0 | August 30, 2004 15:43 |
star is not running the simulation in windows | Arnab | Siemens | 1 | August 2, 2004 02:40 |
FLUENT 5.2.3 running on PIII 733 | Burley Wang | FLUENT | 7 | April 19, 2000 06:03 |
