interFoam ask for a value in a nutkRoughWallFunction
Old   October 30, 2013, 08:01
Default interFoam ask for a value in a nutkRoughWallFunction
Antonio
avigrod is on a distinguished road
I have defined a rough wall bc using nutkRoughWallFunction, in this way (0/nut):
object      nut;
boundaryField
    wall
        type            nutkRoughWallFunction;
        Ks              uniform 0.0001;
        Cs              uniform 0.5;
Following instructions from $FOAM_SRC/turbulenceModels/incompressible/RAS/lnInclude/nutkRoughWallFunctionFvPatchScalarField.H
 Example of the boundary condition specification:
    \verbatim
    myPatch
        Ks              uniform 0;
        Cs              uniform 0.5;
    \endverbatim
When running interFoam it shows the following error message:
0/nut.boundaryField.wall from line 26 to line 28.
    From function fvPatchField<Type>::fvPatchField(const fvPatch& p,const DimensionedField<Type, volMesh>& iF,const dictionary& dict,const bool valueRequired)
    in file /home/opencfd/OpenFOAM/OpenFOAM-2.2.2/src/finiteVolume/lnInclude/fvPatchField.C at line 162.
FOAM exiting
lines 26-28 are the ones I paste here within the 0/nut file.
Why is it asking for a value field, if the wall function does not need it? If I put any value, Would it be used for anything? I mean, if I add a "value uniform 0;", it won't influenced anything, will it?
Thank you in advance!
avigrod is offline   Reply With Quote
Old   August 13, 2014, 08:46
Olivier Benichou
olivier78 is on a distinguished road
same problem here
olivier78 is offline   Reply With Quote
Old   August 14, 2014, 03:49
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
It is just needed for the first iteration and will be overwritten afterwards, so just put uniform 0, or maybe a small value.
tomf is offline   Reply With Quote
boundary condition, wall boundary condition
InterFoam stops after deltaT goes to 1e14 francesco_b OpenFOAM Running, Solving & CFD 9 July 25, 2020 06:36
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 15:26
Problem of InterFoam with LES SpalartAllmarasIDDES keepfit OpenFOAM 3 August 29, 2013 11:21
Gravity & pressure handle in interFoam dav.dap83 OpenFOAM Programming & Development 2 May 22, 2013 11:21
Open Channel Flow using InterFoam type solver sxhdhi OpenFOAM Running, Solving & CFD 3 May 5, 2009 21:58
