Force on aerodynamic bike
Old   August 23, 2014, 04:03
Default Force on aerodynamic bike
Marijo
krembil is on a distinguished road
I am running simpleFoam. The report of the forces on aerodynamic bike is:
# Time forces(pressure,viscous,porous) moment(pressure,viscous,porous) localForces(pressure,viscous,porous) localMoments(pressure,viscous,porous)
1176 ((1.88755 -16.4704 0.0649157),(8.30496 -0.0435128 -0.000451409),(0 0 0)) ((0.0149643 -0.595882 -164.082),(9.27736e-05 0.00486565 -3.26585),(0 0 0))
As one can see, y component of the pressure force (-16.4704) is high, it should be less than 1. I have the same simulation run in Fluent.
I am not sure why this number is so high. The simulation runs without any problems, residuals are low, the mesh is OK.
The force file is:
forces
type forces;
functionObjectLibs ("libforces.so");
outputControl timeStep;
outputInterval 1;
patches ( "BIKE"
"BOTTOM" );
pName p;
UName U;
rhoName rhoInf; // Indicates incompressible
log true;
rhoInf 1.205; // Redundant for incompressible
dragDir (1 0 0);
liftDir (0 0 1);
I have also tried with liftDir (0 1 0) and still get the same numbers.
The BOTTOM patch is just the lower part of the bike with finer mesh.
Thanks in advance!
krembil is offline   Reply With Quote
Old   August 28, 2014, 06:53
Michael D.
MichaelD is on a distinguished road
Hi, sorry for the late reply, just in case you haven't solved this yet:
It's the lift force that's supposed to be less than 1, not the lift coefficient right?
I'm not very experienced in OpenFOAM or c++, but I haven't seen syntax like
patches     ( "BIKE"
                  "BOTTOM" );
before. So maybe what's happening it's only calculating the forces for one of the patches?
I'd either try something like
patches( "(BIKE|BOTTOM)");
or create a group like they do in the motorcycle tutorial.
MichaelD is offline   Reply With Quote
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 11:12
free code to calculate aerodynamic force in re-entry capsule at hypersonic regime gomnam15010 Main CFD Forum 3 November 24, 2013 11:56
Aerodynamic force on an plunging airfoil mahzad Main CFD Forum 0 June 19, 2012 06:08
Force can not converge colopolo CFX 13 October 4, 2011 22:03
DEFINE_CG_MOTION and pressure force Teo Fumagalli FLUENT 0 April 11, 2008 10:25
