Running Propeller with PimpleDyMFoam
Old   July 25, 2014, 10:07
Default Running Propeller with PimpleDyMFoam
30na is on a distinguished road
Hi , I am quite new to openFoam and i want to simulate a wind turbine using pimpleDyMFoam . I have already worked with MRFInterFoam but I can't seem to learn how to work with pimleDyMFoam . I don't even know how to see the mesh in paraFoam .
can u suggest any tutorial or links that could help me with this case or a wind turbine . and by the way is there any other solver i can use for wind turbines ?
30na is offline   Reply With Quote
Old   September 23, 2014, 06:42
Anna Mujal
Muji is on a distinguished road
Dear 30na,
follow the Allrun.pre instructions. To see the geometry with paraFoam, once opened, use the wireframe viewing option and if you want to see carefully create a slide containing the simmetry axis. To see the results use this guide http://www.openfoam.org/version2.1.0/ami.php
Muji is offline   Reply With Quote
Fluent Propeller Simulation NGH FLUENT 6 May 14, 2018 00:16
Foam Fatal IO error when running pimpledymfoam orkavic OpenFOAM Running, Solving & CFD 3 December 18, 2013 16:05
[swak4Foam] Running pimpleDyMFoam with groovyBC lexmatt OpenFOAM Community Contributions 2 August 16, 2013 15:08
Something weird encountered when running OpenFOAM in parallel on multiple nodes xpqiu OpenFOAM Running, Solving & CFD 2 May 2, 2013 04:59
Running PimpleDyMFoam in parallel paul b OpenFOAM Running, Solving & CFD 8 April 20, 2011 05:21
