Problem on compressibleInterDyMFoam
Old   October 11, 2014, 03:09
Default Problem on compressibleInterDyMFoam
Joe Bean
joe061122 is on a distinguished road
Hi, everyone
OpenFOAM 2.3.0 is used and the test case is multiphase/compressibleInterFoam/laminar/depthCharge3D with the dynamicMeshDict in multiphase/interDyMFoam/ras/damBreakWithObstacle. The error is at the 2nd time step, as follows:
Starting time loop
Courant Number mean: 0 max: 0
deltaT = 0.00011904762
Time = 0.000119047619
Selected 960 cells for refinement out of 16000.
Refined from 16000 to 22720 cells.
Selected 0 split points out of a possible 960.
Execution time for mesh.update() = 0.15 s
GAMGPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
time step continuity errors : sum local = 0, global = 0, cumulative = 0
MULES: Solving for alpha.water
Liquid phase volume fraction = 0.498 Min(alpha1) = 0 Min(alpha2) = 0
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver: Solving for T, Initial residual = 8.55321e-09, Final residual = 8.55321e-09, No Iterations 0
GAMG: Solving for p_rgh, Initial residual = 0.088495588, Final residual = 0.00025648365, No Iterations 1
max(U) 9.2807149
min(p_rgh) 99975.122
GAMGPCG: Solving for p_rgh, Initial residual = 5.8000153e-05, Final residual = 3.9737119e-08, No Iterations 2
max(U) 7.6445068
min(p_rgh) 99997.455
ExecutionTime = 0.52 s
Courant Number mean: 0.00015167361 max: 0.03925692
deltaT = 0.00013945578
Time = 0.0002585034014
Selected 3792 cells for refinement out of 22720.
Refined from 22720 to 49264 cells.
--> FOAM FATAL ERROR:
Incompatible size before mapping. Field size: 16000 map size: 22720
From function void MapInternalField<Type, MeshMapper, volMesh>:perator()
Field<Type>& field,
const MeshMapper& mapper
) const
in file lnInclude/MapFvVolField.H at line 73.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::error::abort() at ??:?
#2 at fvMesh.C:?
#3 at fvMesh.C:?
#4 Foam::fvMesh::mapFields(Foam::mapPolyMesh const&) at ??:?
#5 Foam::fvMesh::updateMesh(Foam::mapPolyMesh const&) at ??:?
#6 Foam::dynamicRefineFvMesh::refine(Foam::List<int> const&) at ??:?
#7 Foam::dynamicRefineFvMesh::update() at ??:?
at ??:?
#9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
at ??:?
can you help me? thanks
Joe
joe061122 is offline   Reply With Quote
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
