DynamicMeshDict dynamicRefineFvMesh in 2D
Like Tree3Likes
  • 1 Post By sega
  • 2 Post By sgl101
Old   March 11, 2009, 13:25
Default I was trying to use the dynami
Lukas Fischer
lukasfischer is on a distinguished road
I was trying to use the dynamic Mesh refinement for cells near the surface of multiphase flows in a 2D simulation, but as expected it produces more cell layers in z Direction wich is incompatible with patch type "empty". Is there a way to set mesh refinement in only 2 Dimensions? I tried to read the source code of OpenFOAM-1.5/src/dynamicFvMesh/dynamicRefineFvMesh/dynamicRefineFvMesh.C but i am new to OpenFOAM and don't know C++...
The mesh i use is done with blockMesh. Any help is more than welcome, thanks, Lukas.
lukasfischer is offline   Reply With Quote
Old   March 12, 2009, 04:44
Default As far as I know the mesh refi
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
As far as I know the mesh refinement is done in all 3 space directions. Maybe you should try slip conditions instead of empty for the 3rd direction.
This is what I did with my 2D simulations and dynamic mesh refinement.
mm.abdollahzadeh likes this.
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   March 9, 2010, 08:42
Simon Lewis
sgl101 is on a distinguished road
I have been having the same problem as this, and I think i have solved it using a patch of type symmetryPlane, rather than empty.
mm.abdollahzadeh and dupeng like this.
sgl101 is offline   Reply With Quote
Old   October 18, 2011, 10:23
Awais Ali
owayz is on a distinguished road
Send a message via MSN to owayz
Hallo,
I also have a problem in which I want to apply mesh refinement in 2D. I am really not experienced in using openFOAM. If you could please guide me how to implement that.
I have seen the interDyMFOAM solver but I want to use rhoCentralDyMFOAM. So if some one has already used it successfully, I would be really happy if he could help me in any possible way. (i.e. if they could send me their case files and folders, it would be really helpful for me to implement the same thing for my problem.)
Regards,
Awais
owayz is offline   Reply With Quote
Old   November 10, 2014, 07:19
Hossein
atoof is on a distinguished road
Send a message via Yahoo to atoof
Dears,
Is it possible to use extrudeMesh utility after each refinement to remove cells in 3rd direction for adaptive refinement method?
Hossein
atoof is offline   Reply With Quote
DynamicRefineFvMesh dies on snappyHexMesh generated grid chtrapp OpenFOAM Running, Solving & CFD 10 October 4, 2012 06:30
OpenFOAM15dev interDyMFoam problem using dynamicRefineFvMesh eberberovic OpenFOAM Bugs 6 January 14, 2010 05:18
DynamicRefineFvMesh dies on snappyHexMesh generated grid chtrapp OpenFOAM Running, Solving & CFD 0 January 29, 2009 12:07
