LES Boundary Conditions for Pipe Flow
Old   November 12, 2014, 12:44
Default LES Boundary Conditions for Pipe Flow
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Hello everyone,
I am currently trying to model some spray evaporation and chemistry and want to start using LES to resolve the spray velocity distribution better. I was previously using RANS w/k-epsilon and obtaining decent flow with the following BCs:
U: inlet = fixedValue (average U)
outlet = zeroGradient
p: inlet = inletOutlet
outlet = outletInlet
k: inlet = calculated
When running the same case in LES, I get very peculiar velocity fluctuations (pictures attached). Not a ton of experience with LES, so I figure there is a better way to set the BC. Inlet is on the left side, outlet on the right. Cylindrical pipe with walls BC specified for each. Length is 8m, diameter is 0.3m. Using an O-grid, total cells are about 320K
Thanks!
mturcios777 is offline   Reply With Quote
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
Appropriate Boundary conditions for jet flow in open domain shrutidhara.123 FLUENT 0 August 5, 2014 10:27
Radiation interface hinca CFX 15 January 26, 2014 17:11
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Boundary Conditions for Incompressible Flow Bob FLUENT 0 April 7, 2006 21:28
