unexpected constant Temperature on a clip surface
Old   August 4, 2015, 04:50
Default unexpected constant Temperature on a clip surface
SK
Sungki is on a distinguished road
Hello Foamers,
I am a newbie at openFoam.
Now I am struggling with heat transfer problem of a simple box with heat sources using buoyantSimpleFoam. I used P1 radiation model at first but I changed it to fvDOM model because I thought fvDOM is more proper with this small box.
Let me say about system first.
Geometry is a box(600X400X400mm) with 4 heat sources on a ceiling surface. there is air inside the simple box(Look at attached geometry).
ceiling, floor : insulated
fixedWalls(sidewalls): 473K(initial T)
4 heat sources on ceiling(circular shape): constant 1273K
air: 473K(initial T)
outer Temerature: 293K
There is no chemical reaction inside the box.
At first, I expect there is major radiation with convection and conduction due to the large temperature difference and that the temperature of fixedWalls and air needed to be changed with iterations. Unfortunately, my expectation looks wrong.
(Q1) There is big temperature difference between air(473K) inside this small box and heat sources(1273K) on ceiling surface. why did the temperature of air change slightly?
After several iterations, the temperature of air did not look on watching temperature profile after 9400 iterations.
constant folder file is 26M. If there is anyone who want this, I will send it to him.
(Q2) I set fixedWalls as varying temperature bc with 0/T folder as follows.
| \\ / O peration | Version: 2.3.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object T;
dimensions [0 0 0 1 0 0 0];
internalField uniform 473; // air Temperature 200 C
boundaryField
floor
type zeroGradient; // floor surface insulated
ceiling
type zeroGradient; // ceiling surface insulated
fixedWalls
type externalWallHeatFluxTemperature;
kappa fluidThermo;
kappaName default;
Qr Qr;
h uniform 3; //heat transfer coefficient (W/Km2)
thicknessLayer 0.003; //thickness(m)
Ta 293; // ambient Temperature
value uniform 473; // inintial Temperature
circle
type fixedValue;
value uniform 1273; //heat source 1,000 C
Is there anyone who give me some advice for this Temperature bc?
system/fvsolution
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
p_rgh
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0.01;
Ii
solver GAMG;
tolerance 1e-4;
relTol 0;
smoother symGaussSeidel;
cacheAgglomeration true;
nCellsInCoarsestLevel 10;
agglomerator faceAreaPair;
mergeLevels 1;
maxIter 5;
nPreSweeps 0;
nPostSweeps 1;
"(U|h|k|epsilon)"
solver PBiCG;
preconditioner DILU;
tolerance 1e-05;
relTol 0.1;
SIMPLE
nNonOrthogonalCorrectors 4;
pRefCell 0;
pRefValue 0;
residualControl
p_rgh 1e-3;
U 1e-4;
h 1e-4;
G 1e-4;
// possibly check turbulence fields
"(k|epsilon|omega)" 1e-4;
"ILambda.*" 1e-4;
relaxationFactors
fields
rho 0.2;
p_rgh 0.7;
equations
U 0.2;
h 0.2;
k 0.5;
epsilon 0.5;
"ILambda.*" 0.7;
For this file, I adjusted residual control, relaxation factor of rho and nNonOrthogonalCorrectors.
I appreciate your reading and attention and Thank you in advance.
Have a nice day!!
Sungki is offline   Reply With Quote
buoyantsimplefoam, convection, heat transfer, radiation
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 07:15
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
Assigning constant temperature to an interface boundary in a conjugate HT. fshak92 STAR-CCM+ 3 February 16, 2012 07:36
constant surface heat flux Andrew Hayes Main CFD Forum 4 March 16, 2006 07:19
Stanton Number and Arbitrary Surface Temperature Boris Vaisman Main CFD Forum 1 March 9, 2006 04:43
