simpleFoam + cyclic pipe = unstable?
Like Tree4Likes
  • 1 Post By RodriguezFatz
  • 2 Post By alexeym
Old   November 27, 2014, 05:25
Default simpleFoam + cyclic pipe = unstable?
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Hi all,
I usually use profile for U,k,epsilon,omega from cyclic pipe simulations as input for my actual case. Unfortunately, I don't get them converged in openFOAM.
So the setup is a short pipe that I mesh with ICEM:
After loading the mesh to openFoam (fluent3dMeshtoFoam), I change the constant/polyMesh/boundary file to:
|  \\    /   O peration     | Version:  2.3.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       polyBoundaryMesh;
    location    "constant/polyMesh";
    object      boundary;
3
    PER_PIPE_INLET
        type            cyclic;
        nFaces          3060;
        startFace       170068;
        neighbourPatch    PER_PIPE_OUTLET;
    PER_PIPE_OUTLET
        type            cyclic;
        nFaces          3060;
        startFace       173128;
        neighbourPatch    PER_PIPE_INLET;
    PER_PIPE_WALL
        type            wall;
        inGroups        1(wall);
        nFaces          2584;
        startFace       176188;
Then, I change every boundary condition (p,U,k,epsilon) for the inlet and outlet in my 0/ directory to "cyclic":
PER_PIPE_INLET
        type cyclic;
    PER_PIPE_OUTLET
        type cyclic;
I set the system/fvOptions to
|  \\    /   O peration     | Version:  2.2.1                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvOptions;
momentumSource
    type            pressureGradientExplicitSource;
    active          on;            //on/off switch
    selectionMode   all;       //cellSet // points //cellZone
    pressureGradientExplicitSourceCoeffs
        fieldNames  (U);
        Ubar        ( 70 0 0 );
In this case, I use realizableKE model with wallfunctions for the pipe walls. But this whole problem also happens for wall resolved flow and other turbulence models.
This is how a typical residual plot looks like:
So I get these crazy jumps in residuals and no smooth convergence at all. However, profiles of the solution look reasonable (here "U"):
What I already tried:
  • all different kinds of schemes, for gradient, with and without limiters, also for convective fluxes. Laplacian with and without correction... I think I tried every possible combination in that file...
  • solver settings, more or less tolerance, reducing relaxation factors,...
  • changing initial conditions
I know from a different thread, that others have comparable problems with channel flows + cyclic + simpleFoam.
Now: Can anyone please help me?
albet likes this.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   November 27, 2014, 10:06
Philipp
With the mappedPatch boundary I get pretty nice convergence, just as I expected:
Old   November 27, 2014, 12:05
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
maybe I my guess on dimensions of the tube is not quite correct. Here's the case (attached to the message) with cyclic inlet/outlet and it seems to be converging (though rather slow). I've stopped simulation around 900th iteration (decided to reduce relTol of linear solvers and it seems to increase convergence rate), residuals evolution plot is also attached to the message.
As usual, mesh is in GEO format, so you need Gmsh to run the case.
alexeym is offline   Reply With Quote
Old   November 27, 2014, 15:26
Alexey Matveichev
Though it seems, simulation got stuck at pressure residuals of order 1e-2.
RodriguezFatz and albet like this.
Old   November 28, 2014, 06:13
Philipp
Right, it's always like "Yeahaaa it works!!! .... well... no..."
Old   November 28, 2014, 06:42
Florian Ries
itchy is on a distinguished road
Hi Philipp,
I have the same problem with pipe. When I do the simulation with LES it works fine, but with RANS I don't get a convergent case.
For RANS I tried pimpleFoam and simpleFoam. The results looks not so bad (but not good enough), but the residuals are far from good.
How do you use mappedPatch boundary for pipeflow???
Do you use it with fvOptions??
kind regard
Florian
itchy is offline   Reply With Quote
Old   December 1, 2014, 03:53
Philipp
I changed the boundary file to
Inlet
        type            mappedPatch;
        samplePatch    Outlet;
        sampleMode    nearestPatchFace;
        offsetMode uniform;
        offset (0 0 0.075);
        nFaces 6180;
        startFace 3689820;
    Outlet
               type patch;
               nFaces 6180;
               startFace 3696000;
and deleted the fvOptions. "Offset" is obviously the offset between inlet and outlet.
Now, in my "0" directory I made some changes:
Velocity:
    Inlet
        type mapped;
    value uniform (0 0 9.2);
    setAverage true;
    average (0 0 9.2);
    Outlet
        type inletOutlet;
    inletValue uniform (0 0 0);
    value uniform (0 0 0);
Here, velocity will be regulated to an average of 9.2
pressure:
   Inlet
        type            zeroGradient;
    Outlet
        type fixedValue;
        value uniform 0;
All other values, such as "k":
    Inlet
        type            mapped;
    value           uniform 1e-12;
    setAverage     false;
    average     1e-12;
    Outlet
        type         inletOutlet;
    inletValue     uniform 1e-12;
I hope it works.
Philipp.
SHUBHAM9595 likes this.
Old   December 1, 2014, 04:56
Florian Ries
Hi Philipp,
thx for your help.
k-epsilon works now. I will test some other models (k-omega, v2f ...).
I am a little bit confused why the cyclic bc + fvOptions does not work. I have done it with LES and everything works, but for RANS no chance.
kind regards
Florian
Old   December 1, 2014, 05:17
Philipp
I read a comment in this forum (don't know where) where someone states, that he thinks SIMPLE needs some kind of additional correction to work with cyclic. I don't know if that is true, but if PIMPLE / PISO works and SIMPLE doesn't it is at least some good idea...
Old   December 1, 2014, 05:28
Florian Ries
I have tested it with piso and pimple. The convergence was better but not good. With PISO/Pimple you can do some pseudo-timestepping. This improves your convergence. This works as well with the mapped bc. I will give it a shot and compare the rate of convergence.
I can live with your solution (using mapped boundary + SIMPLE).
kind regards
Florian
How to setup cyclic BCs in simpleFOAM hhuang84 OpenFOAM Running, Solving & CFD 14 December 8, 2016 11:39
Possible createPatch/createBaffles bug? simpomann OpenFOAM Bugs 2 July 15, 2014 07:07
Problems with Cyclic & init. BCs for turbulent (k-eps) pipe flow florian_krause OpenFOAM 3 December 1, 2012 04:11
CYCLIC BC in pipe flows matthias OpenFOAM 0 November 5, 2009 10:52
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
