Modelling Torricelli cylindre with buoyantSimpleFoam - problem with p_rgh
Old   November 22, 2014, 17:17
Default Modelling Torricelli cylindre with buoyantSimpleFoam - problem with p_rgh
Coheur
jocoheur is on a distinguished road
Dear Foamers,
I would like to modelize a case like in the Torricelli's cylinder (http://en.wikipedia.org/wiki/Torricelli%27s_law) with one inlet at the top and three outlets on the right side.
I'm using buoyantSimpleFoam, removing turbulence and setting the temperature constant, so that I only have the effect of the gravity influencing my flow.
I'm using atmospheric pressure for the BC of my three outlets for p_rgh and a small velocity is imposed at the inlet. p field is calculated from p_rgh. Pressure fields p_rgh and p are correctly computed, but since openFoam compute U using p_rgh = p - rho*g*h, I don't see the effect of the gravity on the flow (in fact, it is the same as using icoFoam, velocities at the three outlets are the same). I would like to use p instead of p_rgh to have my flow with different velocities at the outlet.
The questions are: How can I make openFoam using my static pressure p? Should I use an other solver for my problem?
Here are the results obtained for velocity field U, p and p_rgh
Thanks in advance
Joffrey
jocoheur is offline   Reply With Quote
buoyantsimplefoam, gravity driven, openfoam, p_rgh, torricelli
Fan Modelling Problem in CFX Jenny CFX 8 September 11, 2007 13:59
SST-DES modelling problem Yang CFX 2 May 18, 2007 06:22
Problem with VOF open channel modelling Biswanath Mahato FLUENT 1 September 14, 2006 04:20
problem about modelling fluidized bed! xfish FLUENT 3 November 6, 2003 08:42
modelling of conjugate heat transfer problem ajay chandra FLUENT 1 October 28, 2003 06:51
