p_rgh problem during parallel run
Old   November 23, 2014, 09:01
Default p_rgh problem during parallel run
musaddeque hossein
musahossein is on a distinguished road
Dear all:
I am running SloshingTank2D. OpenFoam version 2.2.1. I am providing discrete displacements to OpenFoam by updating the .dat (displacement file) as follows:
Here the number in the first row refers to the number of lines of data (2 in this case)
The first column in parenthesis is the time and the third column is the displacement.
2
( 0.1200000000 (( 0.0000000000 0.018321915799882 0.0000000000) ( 0.0000000000 0.0000000000 0.0000000000)))
( 0.1400000000 (( 0.0000000000 0.035117389491237 0.0000000000) ( 0.0000000000 0.0000000000 0.0000000000)))
I have another program that generates the displacements at 0.02 second intervals and then modifies the displacement.dat file. After doing this it updates the controlDict file start and end times as well as shown below, where the start time corresponds to 0.12 seconds and the end time corresponds to 0.14 seconds.
/*--------------------------------*- C++ -*-----------------------------------|
| \\ / O peration | Version: 2.0.1 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
// * * * * * * * * new file * * * * * * * * * * * * * * * * * * * * * * * * * * //
application interDyMFoam;
startFrom startTime;
startTime 0.12;
stopAt endTime;
endTime 0.14;
deltaT 0.001;
writeControl adjustableRunTime;
writeInterval 0.002;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression compressed;
timeFormat general;
timePrecision 6;
runTimeModifiable yes;
adjustTimeStep yes;
maxCo 0.5;
maxAlphaCo 0.5;
maxDeltaT 1;
When I run OpenFOAM, it does the analysis upto 0.12 seconds and does not proceed any further. The log file stops at p_rgh. Any ideas why this is happening? If it is not a problem at time steps before this, why is it occuring at 0.12?
| \\ / O peration | Version: 2.2.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
Build : 2.2.1-57f3c3617a2d
Exec : interDyMFoam -parallel
Date : Nov 23 2014
Time : 08:55:54
Host : "CFS-Server"
PID : 25657
Case : /home/cfsengineers/OpenFOAM/cfsengineers-2.2.1/run/tutorials/multiphase/interDyMFoam/ras/sloshingTank2D
nProcs : 6
Slaves :
5
"CFS-Server.25658"
"CFS-Server.25659"
"CFS-Server.25660"
"CFS-Server.25661"
"CFS-Server.25662"
Pstream initialized with:
floatTransfer : 0
nProcsSimpleSum : 0
commsType : nonBlocking
polling iterations : 0
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0.12
Selecting dynamicFvMesh solidBodyMotionFvMesh
Selecting solid-body motion function tabulated6DoFMotion
Applying solid body motion to entire mesh
Reading field p_rgh
I look forward to comments / suggestions. Thankyou.
musahossein is offline   Reply With Quote
p_rgh, time is greater than
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 10 February 7, 2024 21:50
First Parallel Run - need some help Gian Maria OpenFOAM 3 June 17, 2011 12:08
nonNewtonianIcoFoam - problem with parallel run chris_sev OpenFOAM Bugs 4 April 1, 2009 09:13
Parallel run with engineFoam francesco OpenFOAM Bugs 1 November 25, 2008 07:06
Problem on Parallel Run Setup Hamidur Rahman CFX 0 September 23, 2007 17:11
