November 23, 2014, 09:01 |
p_rgh problem during parallel run
musaddeque hossein
Rep Power: 18 |
Dear all:
I am running SloshingTank2D. OpenFoam version 2.2.1. I am providing discrete displacements to OpenFoam by updating the .dat (displacement file) as follows: Here the number in the first row refers to the number of lines of data (2 in this case) The first column in parenthesis is the time and the third column is the displacement. 2 ( ( 0.1200000000 (( 0.0000000000 0.018321915799882 0.0000000000) ( 0.0000000000 0.0000000000 0.0000000000))) ( 0.1400000000 (( 0.0000000000 0.035117389491237 0.0000000000) ( 0.0000000000 0.0000000000 0.0000000000))) ) I have another program that generates the displacements at 0.02 second intervals and then modifies the displacement.dat file. After doing this it updates the controlDict file start and end times as well as shown below, where the start time corresponds to 0.12 seconds and the end time corresponds to 0.14 seconds. /*--------------------------------*- C++ -*-----------------------------------| | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | |*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * new file * * * * * * * * * * * * * * * * * * * * * * * * * * // application interDyMFoam; startFrom startTime; startTime 0.12; stopAt endTime; endTime 0.14; deltaT 0.001; writeControl adjustableRunTime; writeInterval 0.002; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression compressed; timeFormat general; timePrecision 6; runTimeModifiable yes; adjustTimeStep yes; maxCo 0.5; maxAlphaCo 0.5; maxDeltaT 1; When I run OpenFOAM, it does the analysis upto 0.12 seconds and does not proceed any further. The log file stops at p_rgh. Any ideas why this is happening? If it is not a problem at time steps before this, why is it occuring at 0.12? /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.1-57f3c3617a2d Exec : interDyMFoam -parallel Date : Nov 23 2014 Time : 08:55:54 Host : "CFS-Server" PID : 25657 Case : /home/cfsengineers/OpenFOAM/cfsengineers-2.2.1/run/tutorials/multiphase/interDyMFoam/ras/sloshingTank2D nProcs : 6 Slaves : 5 ( "CFS-Server.25658" "CFS-Server.25659" "CFS-Server.25660" "CFS-Server.25661" "CFS-Server.25662" ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0.12 Selecting dynamicFvMesh solidBodyMotionFvMesh Selecting solid-body motion function tabulated6DoFMotion Applying solid body motion to entire mesh Reading field p_rgh I look forward to comments / suggestions. Thankyou. |
p_rgh, time is greater than |
area does not match neighbour by ... % -- possible face ordering problem | St.Pacholak | OpenFOAM | 10 | February 7, 2024 21:50 |
First Parallel Run - need some help | Gian Maria | OpenFOAM | 3 | June 17, 2011 12:08 |
nonNewtonianIcoFoam - problem with parallel run | chris_sev | OpenFOAM Bugs | 4 | April 1, 2009 09:13 |
Parallel run with engineFoam | francesco | OpenFOAM Bugs | 1 | November 25, 2008 07:06 |
Problem on Parallel Run Setup | Hamidur Rahman | CFX | 0 | September 23, 2007 17:11 |
