NACA profile - problem with stability of computation |
November 24, 2014, 06:14 |
jiri kozak
Rep Power: 13 |
Hi!
I am quite new in OpenFoam and his world of pain and frustration, therefore excuse me if you find my problem silly. I would like to compute separating cavitation cloud over NACA hydrofoil. I have decidet to start with simplier singlephase simulation using pimpleFoam and realizable k-eps model of turbulence. Unfortunatelly, I met some problems with stability. I am not sure if I set the case properly, so there are my dictionaries at the end of my message. Could you give me some advices? Thank you Simulation description Single phase flow over NACA hydrofoil Velocity inlet, pressure outlet full 3D geometry, Hexahedral mesh realizable k-eps model Problem description: Velocity exceeds reasonable magnitude in the area of the trailing edge. Magnitude of the inlet velocity is 2 m/s. Pictures of the velocity field and detail of the mesh near the hydrofoil are attached to the message. velocity.jpg trailing edge.jpg system.zip properties.zip |
November 25, 2014, 05:53 |
herman eselte
Rep Power: 11 |
try another turbulence model, e.g. kOmegaSST. H |
November 25, 2014, 06:54 |
Vojtech Betak
Rep Power: 18 |
I will try to do following steps
1. checkMesh - dimension convert m/mm 2. check your BC - especially for turbulent quantities 3. change divScheme to 1st order and time scheme to Euler 4. decrease time step turn from pimple algoritm to piso VB |
November 25, 2014, 07:45 |
jiri kozak
Rep Power: 13 |
Thank you!
-I have checked the quality and scale of the mesh, it should be OK -BC should be ok too -I tried to change div schemes and few other things -then I will try k-omegaSST What is the difference between pimple and piso, is there any crucial advantage of PISO algorithm? Have a nice day JK I will tell you about my progress as soon as I will have some results. |
November 25, 2014, 08:30 |
Rep Power: 12 |
In general: Increase nOrthogonalCorrectors up to max 2
or nCorrectors in Piso Loop, depends on your skewness angles Explanations for Piso vs Simple here: http://openfoamwiki.net/index.php/Op...hm_in_OpenFOAM http://openfoamwiki.net/index.php/Op...hm_in_OpenFOAM http://openfoamwiki.net/index.php/PISO |
hydrofoil, naca convergence problem, openfoam, pimplefoam |
Problem reading profile | Bollonga | FLUENT | 3 | March 8, 2024 18:59 |
Problem identifying field of profile | Isaac Pitti | FLUENT | 5 | March 13, 2016 00:54 |
Problem about mutile-nodes parallel computation | tzqfly | OpenFOAM Running, Solving & CFD | 0 | November 12, 2014 02:01 |
pressure contour and velocity profile problem | alee1293 | Main CFD Forum | 0 | July 18, 2014 10:31 |
Stability problem due to turbulent dispersion force in a subcooled boiling model | Edy | OpenFOAM | 7 | August 10, 2011 12:00 |
