November 26, 2014, 12:50 |
Pipe flow heat transfer
aliahmadi
Rep Power: 11 |
hi friends
i am a new user of openfoam and i need to simulate the heat transfer of water in a pipe whit the air out side. can i use bouyantpimplefoam solver. or i should use chtmultiregionfoam solver. i create the geometry with wedge type boundry and toposet rule. please help me |
November 26, 2014, 15:19 |
Nima Samkhaniani
Rep Power: 24 |
You should use bouyantPimpleFoam solver
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
November 26, 2014, 15:22 |
Nima Samkhaniani
Rep Power: 24 |
You should use chtmultiRegionFoam solver, because in your problem, you have different zones
November 27, 2014, 13:53 |
aliahmadi
Rep Power: 11 |
thanks alot nimasam
but i think that in chtmultiregionfoam solver u should have a solid zone. am i right??? thanks. |
November 27, 2014, 14:04 |
With the description of the problem you've provided, you can use almost any solver from solvers/heatTransfer folder. Do you need evolution of the flow field or steady state? Do you need to account for heat transfer outside the tube (not heat just loss through the pipe boundary but heat transfer in air)? Do you need gravity (if you just need to simulate heat transfer in water in the tube within certain assumptions you can even use pimpleFoam and scalarTransport function object)? |
November 27, 2014, 14:25 |
aliahmadi
Rep Power: 11 |
thanks for your response.
yes i need the heat transfer outside the tube .and i can consider the problem steady state or transient.. and i should say that i have two zones. on for water inside the tube. and other for air outside the tube. |
November 27, 2014, 14:43 |
Then it's chtMultiRegionFoam as nimasam said in his last message, because buoyantPimpleFoam assumes single component medium.
Though, I'm trying to imagine tube, water inside, air outside, properties of the water, heat transfer capabilities of the air. And, well, surely I can imagine a desire to cool a pipe with air flow but it looks a little bit strange. |
November 27, 2014, 14:58 |
aliahmadi
Rep Power: 11 |
[QUOTE=alexeym;521437]Then it's chtMultiRegionFoam as nimasam said in his last message, because buoyantPimpleFoam assumes single component medium.
Though, I'm trying to imagine tube, water inside, air outside, properties of the water, heat transfer capabilities of the air. And, well, surely I can imagine a desire to cool a pipe with air flow but it looks a little bit strange.[/QUO why is strange?? |
November 27, 2014, 15:14 |
#9 |
Well, I'd say it's a simulation for the sake of simulation (or you've omitted certain details). As with your current description you still can assume the air as boundary condition. Or if you're interested in the thermo-flow in air, you can assume water as boundary condition.
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
[ANSYS Meshing] heat transfer through a pipe | cfdjunkie | ANSYS Meshing & Geometry | 3 | September 18, 2012 21:53 |
Conjugate heat transfer in reacting flow | ali_1364reza | OpenFOAM | 1 | May 30, 2012 14:15 |
Flow around pipes - heat transfer coefficient on the wall of pipe | doodek | Main CFD Forum | 2 | November 23, 2009 08:48 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
