Artificial high pressure under an impacting droplet using interFoam |
November 29, 2014, 09:24 |
hadisafaei
Hi all.
I'm trying to simulate the impingement of a Glycerin drop to a solid surface using interFoam solver and laminar model(OpenFoam 2.3) .When a droplet approached another surface, air in the gap between them was forced out and it's pressure increased .numerical simulation shows that air pressure increases sharply (up to 100000pa) under the droplet and causes some air trap in the drop . Due to the low speed of droplet(5.94 m/s) this increased pressure seems not be true. Can someone give me a hint on how can I get better results? What could be the reasons? settings are attached below Thanks for any help. |
November 30, 2014, 13:54 |
Hi Hadi,
Welcome to the forum. Well, I ran your case. Actually since we are dealing with incompressible fluids (interFoam) then pressure difference is the parameter we are searching for. In your case this value is 100 pa between droplet center and adjacent surrounding air. Isn't it correct !? Any paper to validate or verify with !? Best.
Learn OpenFOAM in Persian SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member Complex Heat & Flow Simulation Research Group If you can't explain it simply, you don't understand it well enough. "Richard Feynman" |
November 30, 2014, 15:11 |
hadisafaei
Hi Mojtaba
Thanks for your quick reply. ّI think It is necessary to further explain. I mean , the air pressure under droplet when droplet closed to solid surface , not difference between droplet pressure and surrounding air. Yes there are some papers for validation, for example " Air bubble entrapment under an impacting droplet " written by V. Mehdi-Nejad, J. Mostaghimi, and S. Chandra ; phys. Fluids *But there is significant difference between my results and their results.To clear the subject two pictures are attached below. |
November 30, 2014, 15:39 |
In time 0.6 I get something like this,
November 30, 2014, 16:06 |
hadisafaei
Thanks
But i want air pressure before droplet impact to the surface |
high pressure, interfoam |
Artificial high velocities at the interface using interFoam | Arnoldinho | OpenFOAM Running, Solving & CFD | 37 | August 30, 2018 06:25 |
how to replace a shock tube high pressure port by a boundary condition? | immortality | OpenFOAM Pre-Processing | 0 | May 2, 2013 13:43 |
high pressure boundary condition | fragzilla | CFX | 5 | September 14, 2012 02:40 |
Pressure reference in cyclic interFoam | AlmostSurelyRob | OpenFOAM | 7 | February 16, 2011 09:58 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
