November 30, 2014, 09:04 |
CONVERGENCE > MY RESULTS > interpretation
vitor spadeto
Rep Power: 11 |
I have this problem with residual plotting.. no message errors appears .... what is the problem?
I recorded a video relating my problem: https://www.youtube.com/watch?v=rDt4...ature=youtu.be After correct this problem... Can you prepare a Residual file for me? ... I don't know. I desire plot "p" also... Best Regards, Vitor Spadeto Venturin |
November 30, 2014, 11:43 |
It's not a good idea to present text information in video format. Next time just attach Residuals file and a piece of log file. Gnuplot will not plot if there's nothing to plot. Execute your commands from Residuals file in the shell just to see if they return anything at all. Here's what I usually use for plotting residuals: Code:
#!/usr/bin/env gnuplot r_ux = "< grep 'Solving for Ux,' log | awk '{print $8}' | tr -d ," r_uy = "< grep 'Solving for Uy,' log | awk '{print $8}' | tr -d ," r_uz = "< grep 'Solving for Uz,' log | awk '{print $8}' | tr -d ," r_pr = "< grep 'Solving for p,' log | sed -n '0~2p' | awk '{print $8}' | tr -d ," r_epsilon = "< grep 'Solving for epsilon,' log | awk '{print $8}' | tr -d ," r_k = "< grep 'Solving for k,' log | awk '{print $8}' | tr -d ," set logscale y set yrange [5e-7:1] set xlabel 'Time, s' set ylabel 'Residual' set ytics nomirror format "%.0e" plot r_ux w l ls 1 lw 2 title 'ux residual', \ r_uy w l ls 2 lw 2 title 'uy residual', \ r_uz w l ls 3 lw 2 title 'uz residual', \ r_pr w l ls 4 lw 2 title 'pressure residual', \ r_epsilon w l ls 5 lw 2 title 'epsilon residual', \ r_k w l ls 6 lw 2 title 'k residual' pause(-1) |
December 1, 2014, 20:57 |
vitor spadeto
Rep Power: 11 |
Dears, I am beginner and woul like to understand better my results... my simulation are running just now.. and the residuals is keeping in this values... :
DILUPBiCG: Solving for Ux, Initial residual = 1.30388e-06, Final residual = 1.02656e-07, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 2.51207e-05, Final residual = 1.16967e-06, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 2.37728e-06, Final residual = 4.56727e-08, No Iterations 2 GAMG: Solving for p, Initial residual = 1.14214e-05, Final residual = 2.01907e-06, No Iterations 1 GAMG: Solving for p, Initial residual = 6.04496e-06, Final residual = 6.04496e-06, No Iterations 0 GAMG: Solving for p, Initial residual = 6.04496e-06, Final residual = 6.04496e-06, No Iterations 0 time step continuity errors : sum local = 0.000151313, global = 3.31381e-08, cumulative = -0.000114931 ExecutionTime = 2945.06 s ClockTime = 3257 s in this post a guy talk how to interpret these values.. but I dont know if it is correct.. http://www.cfd-online.com/Forums/ope...tml#post300525 this is my fvsolution: Code:
solvers { p { solver GAMG; tolerance 1e-05; relTol 0.1; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; cacheAgglomeration on; agglomerator faceAreaPair; nCellsInCoarsestLevel 10; mergeLevels 1; } "(k|epsilon|R|nuTilda)" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-05; relTol 0.1; } U { solver PBiCG; preconditioner DILU; tolerance 1e-8; relTol 0.1; } } SIMPLE { nNonOrthogonalCorrectors 2; residualControl { p 1e-5; U 1e-5; "(k|epsilon|omega)" 1e-3; } } relaxationFactors { fields { p 0.3; } equations { U 0.7; k 0.7; epsilon 0.7; R 0.7; nuTilda 0.7; } } // ************************************************************************* // the main question is about interpreting of residuals considering fvsolution values.. |
December 2, 2014, 03:59 |
Philipp
Rep Power: 26 |
Hi, I am not sure what your main question is about, but the guy in your link is right.
For your case: Code:
Ux, Initial residual = 1.30388e-06, Final residual = 1.02656e-07, No Iterations 1 Code:
U { solver PBiCG; preconditioner DILU; tolerance 1e-8; relTol 0.1; } Obviously, after one iteration the residual is lower (=1.02656e-07 in your case), that's why the solver tells you it just needed one iteration. You can see, for Uz equation the solver needs two iterations. But there is another criterion, "tolerance 1e-8" in your fvSolution. This means, if the residual is below 1e-8 the solver will stop, no matter if "relTol" is already achieved. So it stops iterating if either the residual is relativly small compared to the intial residual (relTol) or if it is small by means of absolute value (tolerance). For simple algorithm it is important, that the residuals are reduced from one outer iteration (=one of the cycles of Ux,Uy,Uz,p and the turbulence values) to the next and not within one cycle. This is given by the "residualControl" in your fvSolution. It says, that the initial residuals must be below the values you give here. In your case the initial residual of "p" is higher than the value given in fvSolution (1.14214e-05 > 1e-5). That's why simple keeps iterating. Question 2) You need to look at the initial residuals. Just from that number one can not state that it is good enough. Plot the residuals over the iteration and post it. -> Why did you deactivate the turbulence model?
The skeleton ran out of shampoo in the shower. |
December 2, 2014, 05:38 |
vitor spadeto
Rep Power: 11 |
thank you for answer friend! ... with relation plot residuals...
residuals are not working: https://www.youtube.com/watch?v=rDt4FOiIDUc And pyfoam gives a lot of problems.. I prefer residuals file, as in youtube video.. but gives that problem..Do you know what is the problem? about "Why did you deactivate the turbulence model?".. My simulation is laminar..as in the paper I am trying to validate (non newtonian, laminar) |
December 2, 2014, 06:49 |
Philipp
Rep Power: 26 |
Hmm... does the x-gnuplot window open for other scripts? I remember an error I had, where I needed to install some special kind of gnuplot extra package to get the x-window working.
Maybe a simple Code:
sudo apt-get install gnuplot-x11
December 2, 2014, 06:58 |
vitor spadeto
Rep Power: 11 |
woooowwww... it works! I am so happy
I had no success for two weeks .. I will plot here the residuals... It is my first time looking graphically.. can you analize my simulation and give me a basic explanation...in order I can understand analize these graph? I will plot in minutes the graph |
December 2, 2014, 06:59 |
Philipp
Rep Power: 26 |
Hi, I'm glad it works.
Use: Code:
set terminal jpeg font 'Helvetica,10' set output "pressure.jpeg" set logscale y set title "Residuals" set ylabel 'Residual' set xlabel 'Iteration' set format y "%e" set grid plot "< cat log | grep 'Solving for Ux' | cut -d' ' -f9 | tr -d ','" title 'Ux' with lines,\ "< cat log | grep 'Solving for Uy' | cut -d' ' -f9 | tr -d ','" title 'Uy' with lines,\ "< cat log | grep 'Solving for Uz' | cut -d' ' -f9 | tr -d ','" title 'Uz' with lines,\ "< cat log | grep 'Solving for p' | cut -d' ' -f9 | tr -d ','" every 1 title 'p' with lines lc 7
December 2, 2014, 07:19 |
#9 |
vitor spadeto
Rep Power: 11 |
how can I plot for p? my nonorthogonalityCorrectors is 3..
What should I change? Code:
set logscale y set title "Residuals" set ylabel 'Residual' set xlabel 'Iteration' plot "< cat log | grep 'Solving for Ux' | cut -d' ' -f9 | tr -d ','" title 'Ux' with lines,\ "< cat log | grep 'Solving for Uy' | cut -d' ' -f9 | tr -d ','" title 'Uy' with lines,\ "< cat log | grep 'Solving for Uz' | cut -d' ' -f9 | tr -d ','" title 'Uz' with lines,\ "< cat log | grep 'Solving for omega' | cut -d' ' -f9 | tr -d ','" title 'omega' with lines,\ "< cat log | grep 'Solving for k' | cut -d' ' -f9 | tr -d ','" title 'k' with lines,\ "< cat log | grep 'Solving for p' | cut -d' ' -f9 | tr -d ','" title 'p' with lines pause 1 |
December 2, 2014, 07:23 |
#10 |
vitor spadeto
Rep Power: 11 |
December 2, 2014, 07:24 |
#11 |
Philipp
Rep Power: 26 |
Have a look at my last post. Just use "every 4" in the pressure line to plot every 4th p value.
December 2, 2014, 07:33 |
#12 |
vitor spadeto
Rep Power: 11 |
I don't know ...Can you write for me correcting my code?
December 2, 2014, 07:34 |
#13 |
Philipp
Rep Power: 26 |
Just look at my post #6 and change "every 1" in "every 4" to plot just every 4th line
December 2, 2014, 07:37 |
#14 |
vitor spadeto
Rep Power: 11 |
IM SORRY.... I did not see this post.... oO ,, just a moment
December 2, 2014, 07:38 |
#15 | |
Philipp
Rep Power: 26 |
The number of each post is shown in the upper right corner of each post. Scroll up and down until you find a "#6". This is my post. Actually you can just click on this link to scroll there: http://www.cfd-online.com/Forums/ope...tml#post522055
December 2, 2014, 07:41 |
#16 |
vitor spadeto
Rep Power: 11 |
Can you help me to interpret my graph? Is it good? good convergence? I a beginner with this plot.. I dont know if it is good or not |
December 2, 2014, 07:47 |
#17 |
Philipp
Rep Power: 26 |
Hi, I think it looks good, but I don't know your case. But anyway, something is wrong with the plot command. Are you sure you wrote "every 4"? Looks like you wrote "every 3". All residuals should end at the same x-value.
Edit: My fault. If orthogonal correctors is 4, you need to write "every 5". But please post the output of "checkMesh", I don't think that many correctors are necessary.
December 2, 2014, 08:13 |
#18 |
vitor spadeto
Rep Power: 11 |
I fix it...
1- just a beginner's question... what means that Uz finish with 1e-06?means that the difference between the penultimate and last iteration is 1e-06? Is it the initial residual for Uz? pressure.jpeg 2- Can you talk a little about my graph? I dont understand also how to interpret when will gives converged.. my fvsolution is: Code:
/ object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; tolerance 1e-05; relTol 0.01; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; cacheAgglomeration on; agglomerator faceAreaPair; nCellsInCoarsestLevel 10; mergeLevels 1; } "(k|epsilon|R|nuTilda)" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-05; relTol 0.01; } U { solver PBiCG; preconditioner DILU; tolerance 1e-8; relTol 0.01; } } SIMPLE { nNonOrthogonalCorrectors 4; residualControl { p 1e-5; U 1e-5; "(k|epsilon|omega)" 1e-3; } } relaxationFactors { fields { p 0.3; } equations { U 0.7; k 0.7; epsilon 0.7; R 0.7; nuTilda 0.7; } } Sorry for this kind of question.. I am a beginner. Your opinion will open my mind.. |
December 2, 2014, 08:18 |
#19 |
vitor spadeto
Rep Power: 11 |
checkMesh:
Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 129436 faces: 1375651 internal faces: 1316745 cells: 673099 faces per cell: 4 boundary patches: 4 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 0 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 673099 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology inlet_host 380 216 ok (non-closed singly connected) outlet 430 241 ok (non-closed singly connected) wall 57716 28932 ok (non-closed singly connected) inlet_graft 380 216 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.025 -0.0015 -0.0015) (0.02 0.0015 0.0160563) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (-2.40961e-16 -2.09889e-16 1.90397e-16) OK. Max cell openness = 2.81535e-16 OK. Max aspect ratio = 7.39353 OK. Minimum face area = 1.8821e-09. Maximum face area = 7.62702e-08. Face area magnitudes OK. Min volume = 4.50799e-14. Max volume = 6.63018e-12. Total volume = 4.45876e-07. Cell volumes OK. Mesh non-orthogonality Max: 63.5336 average: 14.7407 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.691846 OK. Coupled point location match (average 0) OK. Mesh OK. End |
December 2, 2014, 08:28 |
#20 | |||
Philipp
Rep Power: 26 |
You need the simple (outer) iterations to converge. That's the main objective. One iteration of the "outer" / simple algorithm consist of Ux,Uy,Uz and p solving = one "block" as shown in your third post log. So from iteration to iteration the initial residuals should decrease. This is what you plot in gnuplot. Each of these outer iterations has to solve a linear system of equations. They are set up by the "solver" commands in fvSolution. It's not important that the final residual of each linear solver is low. It just must be low enough so the outer iterations converge. So I would set all "relTol" to 0.1 and only increase them if simple doesn't converge.
higher grid resolution --> later convergence? | cfd-noob89 | Main CFD Forum | 4 | October 31, 2013 09:47 |
Not getting the results after convergence | Agnimitra | Main CFD Forum | 0 | January 16, 2008 00:28 |
Interpretation of Results | Danial | Main CFD Forum | 3 | October 19, 2001 13:38 |
Different Results in Convergence | Figen | FLUENT | 0 | February 9, 2000 16:07 |
convergence problem with SIMPLER | NURAY KAYAKOL | Main CFD Forum | 1 | February 24, 1999 13:43 |
