Pressure stair-step behaviour using rhopimplefoam
Old   December 11, 2014, 07:14
Default Pressure stair-step behaviour using rhopimplefoam
joegi
joegi.geo is on a distinguished road
I wonder if somebody else is experiencing this, I am having an strange stair-step behavior on the pressure when using rhopimplefoam and I don’t manage to pinpoint the reason of this.
The case consists of a simple straight pipe (Poiseuille case, so we have an analytical solution). I am computing the solution using icoFoam, pimpleFoam, and rhoPimpleFoam for the same mesh, physical properties, and same boundary conditions. The peak velocity is about 2.8 m/s, so I expect rhoPimpleFoam to yield to the same results as those of the incompressible solvers. While the velocity is pretty much the same, the pressure along the pipe axis of rhoPimpleFoam shows a stair-step (wiggles) behavior, whereas the pressure reported by the incompressible solvers has a smooth behavior (as expected and desired). At this point, I wonder if you have seen this behavior.
I have used many different numerical schemes and I always see the same behavior. Using finer meshes did not yield to better results.
By the way, I see the same behavior using the Heat transfer and buoyancy-driven flows solvers.
To reproduce the results:
Download the case file and go to rp5:
blockMesh -dict system/blockMeshDict
rhoPimpleFoam
sample -latestTime
Then go to pimple:
blockMesh
pimpleFoam
sample -latestTime
Then compare the solutions for both cases (pressure).
In figure 1 it is plot a comparison between icofoam and rhopimplefoam. In figure 4 it is plot a compariosn between fluent a openfoam. The numerical setup, mesh, bc and ic are identical in fluent.
joegi.geo is offline   Reply With Quote
Old   December 12, 2014, 05:01
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Hi this is probably related to the setting for the writePrecision in your controlDict. If you change this to 12 instead of 6 you will loose the wiggles I assume.
Or you could use binary instead of ascii.
Regards,
Tom
tomf is offline   Reply With Quote
Old   December 12, 2014, 11:38
joegi
Hi Tom,
Thank you for point that out.
This is the second time that this bites me with totally different solvers.
FYI, SnappyHexMesh is also sensitive to this issue.
Now I wonder why do they give the double precision version, and do not save the solution using all the significant digits (as default option).
Have a good one,
jg
Old   December 12, 2014, 12:10
Tom Fahner
Hi
If you are referring to the tutorials as "default option" I would say that I never consider the tutorials as anything else than example cases showing the general working of a solver and the information that is needed. You should check any option they use and see if it fits your purpose and you would get a "best practice" for that solver, after all many tutorials use upwind for many terms in fvSchemes, which should not be used in production runs!
Kind regards,
Tom
Setting up the pressure variation due to tornado in a duct(UDF)+animation guillaume1990 FLUENT 0 March 3, 2014 11:59
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 22:40
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 11:26
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
