Need Help in generating Lift and Drag coefficients over airfoil (2D)
Like Tree1Likes
  • 1 Post By gkarlsen
Old   December 17, 2016, 01:46
Default Need Help in generating Lift and Drag coefficients over airfoil (2D)
Humayunn Asif
jingow is on a distinguished road
Hi guys,
I am doing simulation of an airfoil (naca23012) in OpenFoam and my task is to compare the Drag and Lift coefficients of the simulation to the real experimental data adjusting the velocity.
It has taken me countless attempts in order to get to the point in the files attached. The basic problem that I am having right now is that I am using the "Force" and "ForceCoeffs" function in order to generate the .dat file for post-processing. But unable to do so.
If I involve the function in the controlDict then the error I get is error of unable to find the value of rho
Need your help guys.
P.S The attached file has the function in controlDict "Disabled" making it comment.
File Type: gz 0.tar.gz (792 Bytes, 5 views)
jingow is offline   Reply With Quote
Old   December 17, 2016, 09:12
Geir Karlsen
gkarlsen is on a distinguished road
Didn't review your case file, but it sounds a lot like this issue (see Tobi's response)
Problem calculating forces on blades 2 (for finding forces)
jingow likes this.
gkarlsen is offline   Reply With Quote
Old   December 17, 2016, 11:34
Humayunn Asif
Thanks for the link this pretty much solves the existing problem. Will bother you if something else comes up :P
function
wrong SU2 calculation for lift and drag coefficient for NAC4421 mechy SU2 7 January 9, 2017 05:18
High drag for airfoil compared to XFOIL and wind tunnel data Ry10 SU2 15 October 30, 2016 17:27
Generating the lift and drag coefficients with openFOAM JackJewell OpenFOAM 0 June 14, 2016 09:36
Problem with restart solution in shape_optimization.py robyTKD SU2 Shape Design 21 May 29, 2013 09:26
airfoil: drag and lift coefficients Pedro Clode FLUENT 1 January 1, 2007 12:44
