Best schemes for P1 radiation model
Old   December 2, 2014, 09:24
Default Best schemes for P1 radiation model
chriss85 will become famous soon enough
I'm having some convergence problems when solving the P1 equation:
With this I mean that it often reaches the maximum number of iterations without reaching the prescribed final residual, at least in the first iteration of the PIMPLE loop. In further iterations it will converge faster. I have tried to ease the final residual tolerance once by an order of magnitude and my simulation crashed after a few time steps, so I believe I need to reach at least the current residual.
This has a huge impact on my simulation time and I would like to improve the convergence behavior somehow.
I'm wondering if anyone can recommend appropriate schemes and matrix solvers for such equations?
Related: http://www.cfd-online.com/Forums/ope...e-problem.html
chriss85 is offline   Reply With Quote
Old   December 3, 2014, 05:37
Some results:
  • PCG + DIC 1e-7: DICPCG: Solving for G, Initial residual = 1, Final residual = 13.2432, No Iterations 1001, Radiation calculation took 51.02 s
  • ICCG + DIC 1e-7: DICPCG: Solving for G, Initial residual = 1, Final residual = 13.2432, No Iterations 1001, Radiation calculation took 51.73 s <-- Is this correct? output looks wrong
  • PCG + FDIC 1e-7: FDICPCG: Solving for G, Initial residual = 1, Final residual = 13.2432, No Iterations 1001, Radiation calculation took 50.27 s
  • smoothSolver + GaussSeidel 1e-7: smoothSolver: Solving for G, Initial residual = 1, Final residual = 0.490411, No Iterations 1000, Radiation calculation took 30.88 s
  • smoothSolver + SymGaussSeidel 1e-7: smoothSolver: Solving for G, Initial residual = 1, Final residual = 0.346416, No Iterations 1000, Radiation calculation took 41.23 s
  • smoothSolver + nonBlockingGaussSeidel 1e-7: smoothSolver: Solving for G, Initial residual = 1, Final residual = 0.490411, No Iterations 1000, Radiation calculation took 32.32 s
  • smoothSolver + DIC 1e-7: smoothSolver: Solving for G, Initial residual = 1, Final residual = 0.272356, No Iterations 1000, Radiation calculation took 54.23 s
  • smoothSolver + DICGaussSeidel 1e-7: smoothSolver: Solving for G, Initial residual = 1, Final residual = 0.191594, No Iterations 1000, Radiation calculation took 75.23 s
  • GAMG 1e-7: 45? Not converged after 1000 iterations, crashing later on
Any idea why the smoothSolver performs so much better? From what I know so far GAMG and DIC are most often used, so this is a bit surprising to me.
I then tried to relax the equation in all but the last iteration loop. Relaxing the equation makes it converge much much faster (on the order of 1-2 seconds instead of 30 and with only a few iterations since target residuals of 1e-7 is easily reached), however, as this is not suitable for a transient case, the final iteration mustn't be relaxed AFAIK. The final iteration then shows similar convergence behavior as above, so it doesn't look like this had any advantages. For the record, I tried 5 iterations with a relaxation factor of 0.7.
One more thing I'm going to try is a lower final residual in combination with multiple iterations, but I doubt this is going to help much as the residual isn't dropping very nice at all.
Any other suggestions?
how to define a UDF for the incident radiation in DO radiation model jeniuswx Fluent UDF and Scheme Programming 2 May 10, 2022 08:11
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source silvan CFX 3 June 16, 2014 09:49
P1 radiation model and 2D calculation autumn1012 OpenFOAM Running, Solving & CFD 6 November 11, 2009 02:52
Radiation P1 Model with Spectral Model: Multigray A. Thellmann CFX 0 October 25, 2008 12:44
