moving mesh
Old   December 2, 2014, 11:39
Default moving mesh
Mohammad Sarfaraz
mohammad.sarfaraz is on a distinguished road
Hi
Can OpenFoam handle moving mesh?
If yes, please show me its manual and guide about moving mesh and examples of that.
All the Best
mohammad.sarfaraz is offline   Reply With Quote
Old   December 2, 2014, 12:24
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Hello Mohammad,
OpenFOAM can definitely handle moving meshes, but the functionality has not been well documented in the user manual. Your best sources of information are:
  1. The tutorial cases for moving mesh solvers: anything *DyMFoam
  2. The documentation in the dynamicFvMesh and topoChangerFvMesh classes
  3. ADVANCED: The mesh modifiers in dynamicMesh. These are several fundamental mesh changes that can be added to an polyMesh/fvMesh. You will need to do some programming to get exactly the type of motion you want.
Good luck!
mturcios777 is offline   Reply With Quote
Old   December 2, 2014, 23:40
Mohammad Sarfaraz
Originally Posted by mturcios777 View Post
Hello Mohammad,
Good luck!
Too much thanks,
But I am very new to OpenFoam. Can you provide me the documentation about moving mesh?
Best Regards
Old   December 3, 2014, 13:01
Marco A. Turcios
There isn't much officially besides the source code. This paper is a good place to start; otherwise you'll need to search the web for work others have done.
http://congress.cimne.com/eccomas/cf...pers/01178.pdf
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
How to let the mesh motion solver just solve a small region near a moving boundary? zhajingjing OpenFOAM Running, Solving & CFD 9 April 28, 2016 04:15
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 10:58
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
