Pressure inlet boundary condition for icoFoam
Old   December 18, 2014, 19:57
Default Pressure inlet boundary condition for icoFoam
Joseph Nichols
josephn is on a distinguished road
Hi All,
I am trying to run a simple simulation of a leaky capillary using the icoFoam solver. I have run the same simulation using a solver I wrote for a class a few years ago and wanted to compare results. Unfortunately I am having trouble with the boundary conditions and am exasperated trying to solve the issue.
The flow should be entirely pressure driven with fixed pressures at each boundary. My blockMeshDict looks like this
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 0.00001;
vertices
    (0 0 0)
    (3 0 0)
    (4 0 0)
    (7 0 0)
    (0 1 0)
    (3 1 0)
    (4 1 0)
    (7 1 0)
    (0 1.1 0)
    (3 1.1 0)
    (4 1.1 0)
    (7 1.1 0)
    (0 4.1 0)
    (3 4.1 0)
    (4 4.1 0)
    (7 4.1 0)
    (0 0 0.1)
    (3 0 0.1)
    (4 0 0.1)
    (7 0 0.1)
    (0 1 0.1)
    (3 1 0.1)
    (4 1 0.1)
    (7 1 0.1)
    (0 1.1 0.1)  //24
    (3 1.1 0.1)  //25
    (4 1.1 0.1)  //26
    (7 1.1 0.1)  //27
    (0 4.1 0.1)  //28
    (3 4.1 0.1)  //29
    (4 4.1 0.1)  //30
    (7 4.1 0.1)  //31
blocks
    hex (0 1 5 4 16 17 21 20) (30 10 1) simpleGrading (1 1 1)
    hex (1 2 6 5 17 18 22 21) (10 10 1) simpleGrading (1 1 1)
    hex (2 3 7 6 18 19 23 22) (30 10 1) simpleGrading (1 1 1)
    hex (5 6 10 9 21 22 26 25) (10 1 1) simpleGrading (1 1 1)
    hex (8 9 13 12 24 25 29 28) (30 30 1) simpleGrading (1 1 1)
    hex (9 10 14 13 25 26 30 29) (10 30 1) simpleGrading (1 1 1)
    hex (10 11 15 14 26 27 31 30) (30 30 1) simpleGrading (1 1 1)
edges
boundary
    inlet
        type patch;
        faces
        (0 16 20 4)
    outlet
    type patch;
    faces
        (3 7 23 19)
    tumorSide
    type patch;
    faces
        (8 24 28 12)
        (12 28 29 13)
        (13 29 30 14)
        (14 30 31 15)
        (11 15 31 27)
    capWall
        type wall;
        faces
        (4 20 21 5)
        (6 22 23 7)
        (5 21 25 9)
        (6 10 26 22)
        (8 9 25 24)
        (10 11 27 26)
        (0 1 17 16)
        (1 2 18 17)
        (2 3 19 18)
    frontAndBack
        type empty;
        faces
            (0 4 5 1)
            (16 17 21 20)
        (1 5 6 2)
        (17 18 22 21)
        (2 6 7 3)
        (18 19 23 22)
        (5 9 10 6)
        (21 22 26 25)
        (8 12 13 9)
        (24 25 29 28)
        (9 13 14 10)
        (25 26 30 29)
        (10 14 15 11)
        (26 27 31 30)
mergePatchPairs
My U and p files are as follows
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 1.2e5;
boundaryField
    inlet
        type            fixedValue;
    value        uniform 1.5e8;
    outlet
        type            fixedValue;
    value        uniform 0;
    tumorSide
        type            fixedValue;
    value        uniform 1.2e5;
    capWall
    type        zeroGradient;
    frontAndBack
        type            empty;
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type            zeroGradient;
    outlet
        type            zeroGradient;
    capWall
        type            fixedValue;
    value        uniform (0 0 0);
    tumorSide
    type        zeroGradient;
    frontAndBack
        type            empty;
And I have attached a picture of the results I am getting so far.
The system is pretty simple so I am sure I am missing something simple, but I have spent all day trying to find it without success so any input would be appreciated.
Thanks in advance,
Joe
edit: I just realized I didn't make it clear what my problem was. Rather than forward flow through my pipe, flow seems to be driven toward the walls where it quickly dies. I need to figure out how to develop normal flow through the system.
Last edited by josephn; December 18, 2014 at 20:03. Reason: Clarification of problem
josephn is offline   Reply With Quote
Old   December 23, 2014, 02:44
Default Found the problem
Joseph Nichols
I was missing a semicolon in the blockMeshDict, so my outlet and walls were getting mixed up. Details, details...
blockmesh, boundary, icofoam
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 03:23
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
