December 30, 2014, 08:47 |
pisoFoam - Too high Courant Numbers
Rep Power: 11 |
I want to simulate a 3d case where a flow in a channel with a square cross section passes a barrier. See the sketch below. It's my very first case after going through the tutorials So, I decided to use pisoFoam since I believe it's well suitable for my case. My problem is that I get incredible high Courant numbers so that my calculation crashes. I've put some info for you. I hope you guys can help me fvSolution: https://dl.dropboxusercontent.com/u/59780963/fvSolution fvSchemes: https://dl.dropboxusercontent.com/u/59780963/fvSchemes checkMesh: https://dl.dropboxusercontent.com/u/59780963/checkMesh And that's the error I get: Time = 0.025 Courant Number mean: 3.03546e+85 max: 1.06297e+89 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 1.44087e-15, No Iterations 1 #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:? #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:? #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:? #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:? #8 Foam::fvMatrix<double>::solve() at ??:? #9 at ??:? #10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #11 at ??:? Floating point exception (core dumped) |
December 30, 2014, 12:32 |
Hasan K.J.
Hey,
The easiest option is to use pimpleFoam where you can set the maximum courant number. If you want use pisoFoam, you need to reduce the time step (delta t) in order to reduce the courant number. Kind Regards, Hasan K.J
"Real knowledge is to know the extent of one's ignorance." - Confucius |
core dumped, floating point error, floating point exception, pisofoam |
Visualizing mesh regions with high courant number? | Endel | OpenFOAM | 2 | August 20, 2013 03:57 |
Does MULES::implicitsolve allow for Courant numbers > 1? | Philip | OpenFOAM | 4 | May 31, 2011 06:25 |
Very high courant number, time step continuity errors and bounding epsilon | erncyc | OpenFOAM Running, Solving & CFD | 1 | March 24, 2011 11:00 |
Energy balance error with high prandtl numbers. | David_010 | OpenFOAM Running, Solving & CFD | 0 | January 20, 2011 05:21 |
high and low reynolds numbers - what does it mean | Bo Busk Jensen | Main CFD Forum | 3 | September 5, 2002 05:41 |
