Problems using fvdom radiation model and convection heat transfer |
January 7, 2015, 09:08 |
JuNNioR
Rep Power: 12 |
One test problem was implemented using fvdom radiation model on BuoyantBousinesqPimpleFoam with a domain between two parallel plates. The upper one is hot with T=1000K (fixed temperature) and the bottom one is insulated (zerogradient). Air flow at 300K and V=15 cm/s was imposed on the input between parallel plates.
It was expected that the temperature on the bottom plane was higher than 300K. But it was not verified! The model was attached. I don't understand what is happening... Someone can help me? |
January 13, 2015, 12:14 |
JuNNioR
Rep Power: 12 |
Nothing????
January 20, 2015, 08:00 |
Pedro
Rep Power: 11 |
I didntīt had time to check the results but I think one of the problems you have is in the definition of the BC conditions for p and p_rgh. Check the file I attached. |
January 22, 2015, 13:01 |
JuNNioR
Rep Power: 12 |
Pedro, I appreciate your response.
But the problem is the heat exchange by radiation, not in the flow. Anyway I will test the suggested changes. |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
Comparison of radiation and convection heat transfer | panos_metal | FLUENT | 0 | December 5, 2011 21:04 |
model forced convection heat transfer on a heat sink | farzad | FLUENT | 0 | September 9, 2010 14:48 |
heat transfer with s2s radiation model in fluent | D. L. | FLUENT | 3 | July 31, 2008 07:40 |
Natural convection - Inlet boundary condition | max91 | CFX | 1 | July 29, 2008 20:28 |
