Prescribed Patch Motion with sixDoFRigidBodyMotion Solver?
Old   September 15, 2014, 13:09
Default Prescribed Patch Motion with sixDoFRigidBodyMotion Solver?
Petr Furmanek
petr.f. is on a distinguished road
Hi all,
I'd like to simulate 2DOF motion of a profile (2D simulation) - at first prescribed motion, then the flutter analysis.
Considering the first case - is it possible to use the sixDoFRigidBodyMotion solver with prescribed motion (e.g. pitching) or is it necessary to use "the old way" - choose the displacementLaplacian solver and prescribe the motion as a part of the boundary condition?
Considering the second case - does anywhere exist a description of the sixDoFRigidBodyMotion model? (the basic set of equations etc.) I've found a presentation by Dubravko Matijasevic, but I'm not sure this is the actual model used in OpenFOAM.
Thanks, Petr.
petr.f. is offline   Reply With Quote
Old   February 16, 2015, 01:43
haze_1986 is on a distinguished road
Originally Posted by petr.f. View Post
Hi all,
Thanks, Petr.
Hi Petr, this is an interesting question as I've noticed the difference recently when comparing interDyMFoam between OpenFOAM and foam extend. The former implements the sixDoFRigidBodyMotion directly in dynamicMeshDict whereas the latter uses displacementLaplacian in dynamicMeshDict, which will eventually point to the sixDoFRigidBodyDisplacement file in the pointDisplacement boundary file. I went briefly into the code and see that it eventually calls sixDoFRigidBodyMotion and it can take in values of restrains and constrains as well. So I guess it is similar but feel free to correct me if I am mistaken or there are any results comparing the two.
haze_1986 is offline   Reply With Quote
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
Getting too many iterations by velocity solving (aborting). Changing U - Solver? suitup OpenFOAM Running, Solving & CFD 0 January 20, 2010 07:45
Motion diffusivity solver has problems with patches moving toward each other bfa OpenFOAM Running, Solving & CFD 2 July 8, 2009 21:35
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
