Problem using large writeInterval values in Modified interPhaseChangeFoam
Old   September 11, 2014, 03:29
Default Problem using large writeInterval values in Modified interPhaseChangeFoam
Paritosh Vasava
vasava will become famous soon enough
I use openFoam 2.3.0. I was exploring possibilities of simulating evaporation-condensation phenomena with openFoam and I came across instructions by Martin Andersen (Link). It is of notice that these instructions are for OF2.0.x.
I modified and compiled interPhaseChangeFoam following these instructions without any problems.
For test example my deltaT is 1e-8. The problem is when I run the test case using a large
writeInterval value e.g. 0.0001 or 0.001 the case diverges with large Courant number error. But when I use a smaller value e.g. 1e-7 or 1e-8 it runs without any problem. This is bit annoying a I have to keep an eye on the hard disk space all the time and delete the additional time steps manually.
Attached are solver from Martin Andersen (OF 2.0.x, myInterPhaseChangeFoam), the test case and OF2.3.0 solver (evapCondFoam).
Any comments??
vasava is offline   Reply With Quote
Old   September 11, 2014, 06:51
Paritosh Vasava
I checked once again. While compiling I get three warnings:
/opt/openfoam230/src/finiteVolume/lnInclude/alphaControls.H: In function ‘int main(int, char**)’:
/opt/openfoam230/src/finiteVolume/lnInclude/alphaControls.H:17:6: warning: unused variable ‘alphaApplyPrevCorr’ [-Wunused-variable]
/opt/openfoam230/src/finiteVolume/lnInclude/alphaControls.H:23:8: warning: unused variable ‘icAlpha’ [-Wunused-variable]
/opt/openfoam230/src/finiteVolume/lnInclude/readTimeControls.H:38:8: warning: unused variable ‘maxDeltaT’ [-Wunused-variable]
Perhaps the problem has something to do with these errors. Any comments on that?
Old   January 27, 2015, 00:24
Default Helo
ARUN
ARUN K RAJ is on a distinguished road
I am facing a similar situation
the same errors i do get while trying to compile the solver. Have u solved this issue?
ARUN K RAJ is offline   Reply With Quote
Old   January 27, 2015, 02:43
Paritosh Vasava
No. I could run the test case without any additional errors but I am not sure if the results are reliable. I havent tested or verified the solver or the solutions since then.
Old   January 27, 2015, 03:02
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
As interPhaseChangeFoam uses PIMPLE algorithm, can you post your PIMPLE dictionary from fvSolution file? What convergence criterion do you utilize within time step?
alexeym is offline   Reply With Quote
evaporation condensation, modified solver, openfoam 2.0.x, openfoam 2.3.0, own solver
Transient problem w/ initial values Julie FLUENT 8 June 6, 2014 07:22
strange node values @ solid/fluid interface - help JB FLUENT 2 November 1, 2008 12:04
Problem with CD and CDv for an airship envelope Luis Díaz FLUENT 0 March 11, 2008 12:14
Transient initial values problem CC CFX 2 August 31, 2007 10:27
Initial Values in Transient problem Xobile Siemens 1 January 19, 2005 04:42
