Face define with 3 points, hex.
Old   March 2, 2015, 07:12
Default Face define with 3 points, hex.
Raitis Lebdevs
rietis is on a distinguished road
Send a message via Skype™ to rietis
Hello everyone.
I am trying to define a wall with 3 points.
With blockMesh I used for every block hex like this:
hex (0 0 1 2 3 3 4 5) (5 5 5) simpleGradient (1 1 1)
And then I defined the wall like this :
(0 2 1 0)
The problem I get is with the checkMesh. It shows several errors :
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.3.0-f5222ca19ce6
Exec   : checkMesh
Date   : Mar 02 2015
Time   : 14:09:29
Host   : "raitis-VirtualBox"
PID    : 8752
Case   : /home/raitis/OpenFOAM/raitis-2.3.0/run/tutorials/incompressible/taskOne
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
    faces:            20950
    internal faces:   18000
    cells:            6500
    faces per cell:   5.99231
    boundary patches: 5
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     6450
    prisms:        50
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
 ***Total number of faces on empty patches is not divisible by the number of cells in the mesh. Hence this mesh is not 1D or 2D.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
    Patch               Faces    Points   Surface topology
    fixedWalls          450      507      ok (non-closed singly connected)
    roof                0        0        ok (empty)
    inlet               0        0        ok (empty)
    outlet              0        0        ok (empty)
    defaultFaces        2500     2553     ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (0 0 -2.36813) (5.62 0.8 1.51)
    Mesh (non-empty, non-wedge) directions (0 0 0)
    Mesh (non-empty) directions (0 0 0)
 ***Number of edges not aligned with or perpendicular to non-empty directions: 1375
  <<Writing 1441 points on non-aligned edges to set nonAlignedEdges
 ***Boundary openness (0.0249084 -8.46057e-17 -1.07283e-17) possible hole in boundary description.
 ***Open cells found, max cell openness: 1, number of open cells 100
  <<Writing 100 non closed cells to set nonClosedCells
    Minimum face area = 0.00032. Maximum face area = 0.215973.  Face area magnitudes OK.
 ***Zero or negative cell volume detected.  Minimum negative volume: -0.0050624, Number of negative volume cells: 3500
  <<Writing 3500 zero volume cells to set zeroVolumeCells
    Mesh non-orthogonality Max: 180 average: 93.8989
 ***Number of non-orthogonality errors: 9625.
  <<Writing 9625 non-orthogonal faces to set nonOrthoFaces
 ***Error in face pyramids: 20850 faces are incorrectly oriented.
  <<Writing 11225 faces with incorrect orientation to set wrongOrientedFaces
    Max skewness = 3.0427 OK.
    Coupled point location match (average 0) OK.
Failed 6 mesh checks.
End
Is there anything I can do if there is another hex region defined on this and another on both on it's sides?
Cheers
Raitis
rietis is offline   Reply With Quote
Old   March 4, 2015, 07:42
Raitis Lebdevs
I solved it, the problem was not well defined blocks for block mesh. One part of the mesh where defined with different direction than the other.
This mesh contains patches of type empty but is not 1D or 2D oric OpenFOAM Running, Solving & CFD 36 November 28, 2016 07:12
error messages about blockmeshing and solving cramsdead OpenFOAM Pre-Processing 2 November 11, 2014 10:53
[blockMesh] blockMesh how to set internal face ? seav OpenFOAM Meshing & Mesh Conversion 2 May 8, 2014 16:10
[blockMesh] apparently the mesh doesn't want to be created in one direction Maxime Thomas OpenFOAM Meshing & Mesh Conversion 1 August 18, 2012 06:05
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
