FSI solver for compressible flow
Old   February 18, 2015, 00:30
Default FSI solver for compressible flow
Albin Johny
albinjohny is on a distinguished road
Hello , I am a fresher in OpenFOAM. I have to do an FSI problem for a wing in a compressible flow. can anybody suggest me which solver i should be using.
I have tried in icoFsiFoam and icoFsiElasticNonLinULSolidFoam, since both are used for incompressible flows, I cannot use them.
Can anybody kindly help, Please
albinjohny is offline   Reply With Quote
Old   February 20, 2015, 10:12
Damon Lee
D_LEE is on a distinguished road
I think you are going to need to edit icoFsiElasticNonLinULSolidFoam to make it compressible. I would resist using icoFsiFoam because I think it doesn't work in parallel.
If you look inside the solver the code inside the solveFluid.H is identical to icoFoam, you might be able to quickly make a solver by pasting the code from something like rhoPisoFoam into there and pasting the extra fields from that compressible solver into createfields.H.
D_LEE is offline   Reply With Quote
Old   March 18, 2015, 00:53
Albin Johny
sorry for the delay. I tried to add rhopisofoam to the icoFsiElasticNonLinULSolidFoam but the solver is not building in foam extend. it shows error. Is ther any thing i can do.
Thankyou
Old   March 18, 2015, 05:45
Damon Lee
I wish I could help more but I am new aswell. icoFsiElasticNonLinULSolidFoam doesn't actually run in parallel, I have tried with proper HronTureckvalues and that doesn't work even with 2 cpus, also doesnt work on my own test geometry, and the solidMechanics support thread has several people with the same problem.
If you only want a steady state solution anyway then I would use icoFsiFoam and follow this report/tutorial:
http://www.tfd.chalmers.se/~hani/kur...edAndFixed.pdf
I have got cavitatingFoam(compressible solver) to work with it.
the instructions work with foam-extend 3.1 mostly, but something needs to be done differently for it to compile, I think it was in createStressMesh.H.
If you want to edit icoFsiElasticNonLinULSolidFoam then maybe you could post the code or tell the forum the compile error your getting?
Solver for an incompressible, turbulent flow with heat transfer tH3f0rC3 OpenFOAM Running, Solving & CFD 9 June 17, 2019 06:12
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 09:52
Suitable solver for Air/Air flow with different temperatures cjm OpenFOAM 1 January 20, 2011 04:17
Troubleshooting Unsteady Incompressible Flow Solver dandalf Main CFD Forum 0 November 15, 2010 10:55
Fatal over flow in solver Nandu CFX 5 September 16, 2002 07:19
