SprayFOAM - Parallel Running Error
Old   February 6, 2015, 08:53
Default SprayFOAM - Parallel Running Error
MürgoHaw's Avatar
Haw
MürgoHaw is on a distinguished road
Hi CFD- family,
i created a case in Sprayfoam on my 16 core workstation. The case is running perfect using 8 cores in parallel running (decomposeParDict). When i try to run with all 16 cores, i got the following error:
".../decomposeParDict" specifies 16 processors but job was started with 8 processors.
my decomposeParDict looks like:
17
18 numberOfSubdomains 16;
19
20 method hierarchicial;
21
22 simpleCoeffs
23 {
24 n ( 2 2 4 );
25 delta 0.001;
26 }
27
28 hierarchicalCoeffs
29 {
30 n ( 2 2 4 );
31 delta 0.001;
32 order xyz;
33 }
34
35 manualCoeffs
36 {
37 dataFile manual_dataFile;
38 }
39
40 metisCoeffs
41 {
42 }
43
44
45 // ************************************************** *********************** //
Can anyone help me?
Thank you very much!
MürgoHaw is offline   Reply With Quote
Old   February 6, 2015, 12:03
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Does your decomposition results in 16 domains? If so, what does the partitioning look like?
mturcios777 is offline   Reply With Quote
Old   February 11, 2015, 22:34
Neilson Whit
wolfindark is on a distinguished road
I think you run the case with "mpirun -np 8" instead of 16...
wolfindark is offline   Reply With Quote
Old   March 20, 2015, 07:04
MürgoHaw's Avatar
Haw
indeed! unfortunately i just forgot to change it in my runscript. thank you very very much!
[OpenFOAM] an error in Calculator's equation immortality ParaView 12 June 29, 2021 00:10
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
