scalarTransportFoam in a 3D microchannel with 3 inlets
Old   June 5, 2015, 06:38
Question scalarTransportFoam in a 3D microchannel with 3 inlets
novo
pnovo is on a distinguished road
Hi all,
I am a a relatively fresh OpenFoem user. Although I have been through the tutorials and been successfull at using ico- and simpleFoam to calculate the laminar flow in microchannels, I have problems to calculate molecule transport in these microchannels (using the scalarTransportFoam). I can run the calculation without errors, but the data ouput is not what I expected. I am using OpenFoam231 and Saolme7.5.1 for generating meshes, in Linux Ubuntu.
I first used simpleFoam to calculate the steady-state velocity profile for a 3D struture. Top 2D view:
/////////////////////////////////////// ____________________________________
--> Inlet1 v=10mm/s, T = 1e-6 -> |___________________________________|
--> Inlet2 v=1mm/s ------------> | ___________________________________|-->Outlet, p=0 (THE INTERNAL LINES DO NOT EXIST
--> Inlet3 v=10mm/s, T=1e-6 ---> |___________________________________| THEY ARE HERE JUST TO MAKE THE SCHEME NICE)
After I ran the simpleFoam, I used the converged solution as initial solution for the scalarTransportFoam by modifying the folders names and removing the "location" in the U and p calculated files. Then I copied the T file from the pitzDaily tutorial and readjust the diffusion constant, and the boundary conditions so that a T value of 1e-6 enters through inlets 1 and 3. Since the flow is laminar, I expect a gradual increase of concentration in the "extrusion" of inlet2, but the results even include negative values.
Sorry for the obscure description, but it would be really nice if anybody have any hint on this.
Thanks
pnovo is offline   Reply With Quote
scalartransportfoam, simplefoam, wrong data
Trapezoidal microchannel and slip velocity. Help needed. thapostol FLUENT 0 March 28, 2014 14:36
Mixture of the same fluid from 2 inlets godon Fluent UDF and Scheme Programming 0 October 15, 2012 08:04
Two pressure inlets problem Medison CFX 1 August 22, 2012 06:50
Multiple Inlets Charlie V FLUENT 0 May 28, 2001 02:29
create Volume with inlets Roman Bohnes FLUENT 10 December 6, 1999 04:43
