Pressure far field
Like Tree2Likes
  • 1 Post By A.D.E
  • 1 Post By A.D.E
Old   August 4, 2011, 11:22
Default Pressure far field
A.D.E is on a distinguished road
I am trying to resolve the flow around an aerofoil. I want to use the pressurefarfield boundary condition around my aerofoil instead of walls, velocity inlet and pressure outlet. Is this possible?? I tried to run the simulation but id does no converge! Can anyone explain how do you set up the pressurefarfield boundary condition? I am running in 2D and my boundary conditions are:
Pressurefafield (around aerofoil)
Wall (aerofoil)
Fronandback empty.
Thank you in advance,
A.D.E.
PS: I am running incompressible flows v=80m/s.
Naveen Raja G L likes this.
A.D.E is offline   Reply With Quote
Old   August 9, 2011, 03:44
Any comments?
Old   August 9, 2011, 08:08
Red face hii
kid
cfdkid
kid is on a distinguished road
Hello A.D.E
Can you explain what is far field boundary condition ?
kid is offline   Reply With Quote
Old   August 9, 2011, 11:23
Thank you for your interest. I used Fluent before and at compressible flows it recommends the use of Pressure far field boundary conditions:
The definition in the fluent manual is:
Pressure far-field conditions are used to model a free-stream condition at infinity, with free-stream Mach number and static conditions being specified. The pressure far-field boundary condition is often called a characteristic boundary condition, since it uses characteristic information (Riemann invariants) to determine the flow variables at the boundaries.
I don’t know if something similar exist in OpenFOAM since I just started using the software.
Thank you in advance for your consideration and time,
Sincerely,
A.D.E
rajibroy likes this.
Old   August 10, 2011, 02:31
Smile hello
kid
cfdkid
A.D.E,
Far field and near filed are two approaches in CFD to calculate drag.
i.e. both these approach would give same drag force
If you use far field you need to calculate "induced drag" + "wave drag" + "vortex drag"
If you are using Near field approch you need to calculate "pressure drag"+"friction drag".
Which ever approach one uses be sure sum of all components will be equal for both approach.
Cheers
CFDkid
Old   March 9, 2016, 11:31
xin
guxin7005 is on a distinguished road
Originally Posted by kid View Post
A.D.E,
Cheers
CFDkid
Hi, CFD kid,
I don't understand why far filed and near field have different drag calculation?
in 2d case, you still need to calculate the vortex drag?
guxin7005 is offline   Reply With Quote
Pressure Rise Error emueller CFX 0 May 5, 2009 11:08
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
How to get Pressure field from velocity field qunwuhe@hotmail.com Main CFD Forum 4 October 14, 2007 07:38
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
order of magnitude analysis atit koonsrisuk Main CFD Forum 3 July 27, 2000 11:59
