March 30, 2015, 08:15 |
Problem with parallel run
António Pires
Rep Power: 11 |
Hello everyone,
I'm using ihfoam to simulate a wave flume. I've done some runs in parallel without any problem but now i'm doing a new one and, when i use the command reconstructPar, i get this error message Time = 14.65 Reconstructing FV fields Reconstructing volScalarFields p nut --> FOAM FATAL IO ERROR: error in IOstream "/home/antonio/IHFOAM/IHFOAM_materials/tutorials/OF222/Klopman_bicromatico/Klopman-kepsilon/processor1/14.65/nut" for operation operator>>(Istream&, List<T>&) : reading entry file: /home/antonio/IHFOAM/IHFOAM_materials/tutorials/OF222/Klopman_bicromatico/Klopman-kepsilon/processor1/14.65/nut at line 1357. From function IOstream::fatalCheck(const char*) const in file db/IOstreams/IOstreams/IOstream.C at line 114. FOAM exiting The first time i got this mistake it was for time = 30 s and i thought that maybe something had gone wrong when doing the simulation so I deleted everything and did the simulation again. Again i got this error message, this time for time = 14.65 s. I really don't know why this happens because every file in the case folder is a copy from cases that already have worked correctly. Additionally, when running ihFoam i get no error at all, only when reconstructing. Any ideia on why is this happening? Thanks António |
area does not match neighbour by ... % -- possible face ordering problem | St.Pacholak | OpenFOAM | 10 | February 7, 2024 21:50 |
First Parallel Run - need some help | Gian Maria | OpenFOAM | 3 | June 17, 2011 12:08 |
nonNewtonianIcoFoam - problem with parallel run | chris_sev | OpenFOAM Bugs | 4 | April 1, 2009 09:13 |
Parallel run with engineFoam | francesco | OpenFOAM Bugs | 1 | November 25, 2008 07:06 |
Problem on Parallel Run Setup | Hamidur Rahman | CFX | 0 | September 23, 2007 17:11 |
