May 3, 2021, 21:26 |
Error: wmake, no such file or directory.
#1 | |
Carlos
Greeting everyone, I'm a kinda new user of OpenFOAM and I need to compile a new solver a teacher gave me, but the thing is that whenever I try to do it using wmake iI get the error "no such file or directory" but when I search for the file manually it is there.
PD: I'm using OpenFOAM 20.12. |
May 4, 2021, 02:09 |
Mark Olesen
Rep Power: 40 |
Looks like you installed from sources, but dont have anything compiled - otherwise you would have the include files properly linked etc.
The fastest is probably for you to get a precompiled setup: https://develop.openfoam.com/Develop...is/precompiled https://develop.openfoam.com/Develop...ompiled/debian Make sure to install the -dev (Debian, Ubuntu) or -devel (suse, Redhat) package. This should be everything you need. |
May 4, 2021, 20:49 |
Carlos
Thanks for the reply, I tried doing that but I'm still getting the same error.
Do you have any other advice? Maybe I did something wrong, but I'm not sure |
compile, no such file or directory, openfoam, solver compilation error, wmake |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 35 | April 29, 2022 15:35 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 10:59 |
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' | mfiandor | OpenFOAM Installation | 2 | January 25, 2010 09:50 |
