An error about the dynamicmesh file of pimpleDymFoam
Old   January 13, 2017, 04:05
Default An error about the dynamicmesh file of pimpleDymFoam
TeiGyou
zxzx is on a distinguished road
Hello, everyone
I am trying to operate a rotating model in pimpleDymFoam. So I put ICEM mesh into OF and change the dynamicMesh file in constant. I found the cellZone is innerCylinderSmall. But I can not find this item in boundary file.
dynamicFvMesh solidBodyMotionFvMesh;
motionSolverLibs ( "libfvMotionSolvers.so" );
solidBodyMotionFvMeshCoeffs
cellZone innerCylinderSmall;
solidBodyMotionFunction rotatingMotion;
rotatingMotionCoeffs
origin (0 0 0);
axis (0 1 0);
omega 158; // rad/s
}I open the cellZone file and found "FLUID_ROTATE_CORE1_TRI", as you see below.
5
type cellZone;
cellLabels List<label>
2395820
0
I paste this item into dynamicMesh file and try to operate it. I get an error in the first pic. I do not know why it can not be run in my model but can be run in example.
So I change the file as the code said. But there is another error in the second pic.
Is there any people could tell me WHY and HOW to deal with it. THANKS.
ZX
File Type: png Screenshot from 2017-01-13 17-59-10.png (48.9 KB, 23 views)
File Type: png Screenshot from 2017-01-13 18-02-39.png (24.6 KB, 21 views)
zxzx is offline   Reply With Quote
Old   January 13, 2017, 04:14
floquation's Avatar
Kevin van As
floquation will become famous soon enough
Read the error message. It literally says that "solidBodyMotionFvMesh" does not exist, hence your problem is that you specify a "dynamicFvMesh" that is nonexistent. It then gives you allowed alternatives.
How did this happen? You probably copied the file between different versions of OpenFoam, in which name conventions changed.
Or is the specified dynamicFvMesh a custom one? In that case, you must include the library in system/controlDict.
What should you use? I don't know - depends on the problem. Judging purely from the name of the dynamicFvMeshes, I reckon "dynamicMotionSolverFvMesh" is what you are looking for.
floquation is offline   Reply With Quote
Old   January 13, 2017, 04:31
TeiGyou
Thank you for your answer.
Yeah, It says "solidBodyMotionFvMesh" does not exist. Actually, this item is not belong the 7 items below. But it can be run in the same PC and the same version of OF.
Surely, I have included the controlDict file and did not change it at all. I agree with u and change it into dynamicMotionSolverFvMesh but the second error happened.
Old   January 13, 2017, 04:39
floquation's Avatar
Kevin van As
The second error says that the keyword "solver" is not specified.
That is, your dictionary is missing a mandatory/obligatory entry.
I'm not sure what exactly it should look like: find a tutorial that uses the "dynamicMotionSolverFvMesh":
cd $FOAM_TUTORIALS
grep -rn "dynamicMotionSolverFvMesh" .
Old   January 14, 2017, 17:49
Pete Bachant
pbachant is on a distinguished road
Your best bet may be to copy the dynamicMeshDict file from tutorials/incompressible/pimpleDyMFoam/propeller, and then change the cellZone.
Home | Twitter | GitHub
pbachant is offline   Reply With Quote
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
