SimpleFoam crash at first loop
Old   April 20, 2015, 15:22
Default SimpleFoam crash at first loop
alvaro
alvariten is on a distinguished road
Hi people,
I'm new user in OF and I appreciate any reply. I'm trying to solve a simple case with high pressure at inlet and low pressure at outlet. And the velocity is unknown in both cases (one of the purposes is to determinate the velocity at output).
First I did was check the mesh, and I think this is ok.
Create polyMesh for time = 0
Time = 0
Mesh stats
    faces:            1020530
    internal faces:   985870
    cells:            334400
    faces per cell:   6
    boundary patches: 4
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     334400
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
    Patch               Faces    Points   Surface topology
    fixedwall           11160    11531    ok (non-closed singly connected)
    inlet               3200     3321     ok (non-closed singly connected)
    outlet              1600     1671     ok (non-closed singly connected)
    sym                 18700    19060    ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (-1.5 -5.55112e-17 -0.7) (0 1.5 1.95)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Mesh (non-empty) directions (1 1 1)
    Boundary openness (-1.45026e-14 1.20956e-14 3.91972e-16) OK.
    Max cell openness = 4.0813e-16 OK.
    Max aspect ratio = 19.5931 OK.
    Minimum face area = 1.1577e-05. Maximum face area = 0.00177197.  Face area magnitudes OK.
    Min volume = 2.02597e-07. Max volume = 3.10095e-05.  Total volume = 1.752.  Cell volumes OK.
    Mesh non-orthogonality Max: 42.9364 average: 6.59459
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 1.19711 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
End
Then I ran the case and after a long time in "Time = 1" the following error is showed:
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    sigmaEps        1.3;
No finite volume options present
SIMPLE: convergence criteria
    field p     tolerance 0.01
    field U     tolerance 0.001
    field "(k|epsilon|omega)"     tolerance 0.001
Starting time loop
Time = 1
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
 in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/simpleFoam"
#8  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Floating point exception (core dumped)
Here I post information about my case.
U
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    fixedwall
        type            zeroGradient;
    inlet
        type            fixedValue;
    value        uniform (0 0 0);
    outlet
        type            fixedValue;
    sym
        type        symmetry;
p
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 100000;
boundaryField
    fixedwall
        type            zeroGradient;
    inlet
        type            fixedValue;
        value           uniform 100000;
    outlet
        type            fixedValue;
        value           uniform 0;
    sym
        type        symmetry;
k
internalField   uniform 0.375;
boundaryField
    fixedwall
        type            kqRWallFunction;
        value           uniform 0;
    inlet
        type            fixedValue;
        value           uniform 0.375;
    outlet
        type            fixedValue;
        value           uniform 14.855;
    sym
        type        symmetry;
epsilon
dimensions      [0 2 -3 0 0 0 0];
internalField   uniform 14.855;
boundaryField
    fixedwall
        type            epsilonWallFunction;
    inlet
        type            fixedValue;
    outlet
        type            fixedValue;
    sym
        type        symmetry;
nut
dimensions      [0 2 -1 0 0 0 0];
internalField   uniform 0;
boundaryField
    fixedwall
        type            nutkWallFunction;
        value           uniform 0;
    inlet
        type            calculated;
        value           uniform 0;
    outlet
        type            calculated;
        value           uniform 0;
    sym
        type        symmetry;
transportProperties
transportModel  Newtonian;
nu              nu [ 0 2 -1 0 0 0 0 ] 1e-05;
CrossPowerLawCoeffs
    nu0             nu0 [ 0 2 -1 0 0 0 0 ] 1e-06;
    nuInf           nuInf [ 0 2 -1 0 0 0 0 ] 1e-06;
    m               m [ 0 0 1 0 0 0 0 ] 1;
    n               n [ 0 0 0 0 0 0 0 ] 1;
BirdCarreauCoeffs
    k               k [ 0 0 1 0 0 0 0 ] 0;
RASProperties
RASModel        kEpsilon;
turbulence      on;
printCoeffs     on;
ControlDict
application     simpleFoam;
startFrom       latestTime;
startTime       0;
stopAt          endTime;
endTime         500;
deltaT          1;
writeControl    timeStep;
writeInterval   10;
purgeWrite      5;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
fvSchemes
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      bounded Gauss upwind;
    div(phi,k)      bounded Gauss upwind;
    div(phi,epsilon) bounded Gauss upwind;
    div(phi,R)      bounded Gauss upwind;
    div(R)          Gauss linear;
    div(phi,nuTilda) bounded Gauss upwind;
    div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear limited 0.222;
interpolationSchemes
    default        linear;
    interpolate(U) linear;
snGradSchemes
    default         limited 0.222;
fluxRequired
    default         no;
    p               ;
fvSolution
solvers
    p
        solver          GAMG;
        tolerance       1e-06;
        relTol          0.1;
        smoother        GaussSeidel;
        nPreSweeps      0;
        nPostSweeps     2;
        cacheAgglomeration on;
        agglomerator    faceAreaPair;
        nCellsInCoarsestLevel 10;
        mergeLevels     1;
    "(U|k|epsilon|R|nuTilda)"
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-05;
        relTol          0.1;
SIMPLE
    nNonOrthogonalCorrectors 0;
    residualControl
        p               1e-2;
        U               1e-3;
        "(k|epsilon|omega)" 1e-3;
relaxationFactors
    fields
        p               0.3;
    equations
        U               0.7;
        k               0.7;
        epsilon         0.7;
        R               0.7;
        nuTilda         0.7;
I thought change U and p values... or change the patch type. Maybe the k, epsilon values are the problem... I don't know and before to change anything without knowing I'd like to hear your opinions to fix the problem. I'm here to learn and any help or advice is welcome.
Regards.
alvariten is offline   Reply With Quote
Old   April 21, 2015, 01:25
Vojtech Betak
betakv is on a distinguished road
I have seen there an error, that is connected with the wrong definition of boundary conditions. Usually on inlet (in the case of U, k, epsilon) you are defining fixed value and on outlet zeroGradient or inletOutlet should be specified. For pressure you have to presribed on inlet zeroGradient and on outlet fixedValue.You can used also totalPressure for p and pressureDirectedInlet for Uin the case of inlet BC
Please check some tutorials and compared it with your case.
betakv is offline   Reply With Quote
Old   April 27, 2015, 04:33
alvaro
Hi Vojtech,
Thanks for reply. I tried all you suggested. After to read many post I think the best option for my Bc's are:
Totalpressure (inlet) and fixedValue (outlet)
pressureInletOutletVelocity (inlet) and inletOutlet (outlet)
What do you think?
But my problem still appear... I tried to change the Numerical Schemes to 1st Order, I tried to change the Turbulence Model (Laminar, k-e...) even tried with solver pisoFoam and the same Bc's.
I checked pitzDaily tutorial because is similar to my problem. I caught case folders and changed the geometry and the respective patchfields but neither worked.
Always cashed in the first loop:
Time = 1
smoothSolver:  Solving for Ux, Initial residual = 0, Final residual = 0, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 1
#3  Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#5  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#6  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#7  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/simpleFoam"
#9  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
/home/alvaro/OpenFOAM/Engys/N2D_pisoFoam/solver_serial.run: line 30:  4371 Floating point exception(core dumped) $SOLVER -case $CASE 2>&1
      4372 Done                    | tee $LOG
It's strange to me that the residual values of velocity are 0, what this means?
What more could I do?
Cheers.
Old   April 27, 2015, 05:48
Vojtech Betak
I think there is still an error in your BC. Can you post it?
Old   April 27, 2015, 14:14
alvaro
Hi Vojtech,
p
 dimensions [ 0 2 -2 0 0 0 0 ];
internalField uniform 1000.0;
boundaryField
    back
        type empty;
    front
        type empty;
    inlet
        type totalPressure;
        p0 uniform 1000;
        value uniform 1000;
        rho none;
        psi none;
        U U;
        phi phi;
        gamma 1;
    outlet
        type fixedValue;
        value uniform 100;
    sym
        type symmetryPlane;
    wall1
        type zeroGradient;
    wall2
        type zeroGradient;
U
dimensions [ 0 1 -1 0 0 0 0 ];
internalField uniform (0.0 0.0 0.0);
boundaryField
    back
        type empty;
    front
        type empty;
    inlet
        type pressureInletOutletVelocity;
        value uniform ( 0 0 0);
    outlet
        type inletOutlet;
        inletValue uniform (0 0 0);
    sym
        type symmetryPlane;
    wall1
        type fixedValue;
    wall2
        type fixedValue;
And this show the terminal when I run the case (if if help)
Starting time loop
Time = 1
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.314744, No Iterations 1000
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 0.285886, No Iterations 1000
The main idea of the study is I have to set the pressure at the inlet and the outlet. And in any way I look for to know the velocity at inlet and outlet. What would you propose?
Thanks
Old   August 17, 2015, 07:17
Default simpleFoam crashes in first loop
Surya Kiran
peravali is on a distinguished road
hello alvaro,
I am having similar problem as you and my boundary conditions seems ok.
Were you able to find out the problem?
//surya
peravali is offline   Reply With Quote
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
simpleFoam crushes at 1st Time loop. seav OpenFOAM Running, Solving & CFD 18 June 4, 2013 08:18
[CAD formats] my stl surface is seen as just a line rcastilla OpenFOAM Meshing & Mesh Conversion 2 January 6, 2010 01:30
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 15:57
