buoyantBoussinesqSimpleFoam with porous zone (source term) problem
Old   May 26, 2015, 08:05
Exclamation buoyantBoussinesqSimpleFoam with porous zone (source term) problem
cissystef is on a distinguished road
Hi everyone,
Apart from previous post using porousBafflePressure for a zero-thickness porous plate, I also wanted to test it out using DarcyForchheimer source term for a constructed porous zone.
Geometry:
So the geometry is the same, a duct (0.6*0.6*3) with a porous zone inside (0.6*0.6*0.1).
0 folder - initial condition:
the most important 3 parameters for setup:
U: walls (fixedValue; uniform (0 0 0));
inlet (fixedValue; uniform (0.88 0 0));
outlet (zeroGradient);
T: walls and outlet (zeroGradient)
inlet (fixedValue, uniform 300);
p_rgh: walls and inlet (fixedFluxPressure, uniform 0)
outlet (fixedValue, uniform 0)
System folder:
However, I found out that the results are not consistent with the experiment The DarcyForchheimerCoeffs I set in fvOptions are obtained from Delta p = -(D*mu*U + 0.5*I*rho*|U|^2 )L:
d d [0 -2 0 0 0 0 0] (6.3e4 0 0);
f f [0 -1 0 0 0 0 0] (17.73 0 0);
coordinateSystem
type cartesian;
origin (0 0 0);
coordinateRotation
type axesRotation;
e1 (1 0 0);
e2 (0 1 0);
My flow direction is along x-axis, and my porosity directions (not quite sure about this) set for e1 e2 are as indicated above. I did change e1 e2 to a different orientation, the results are still quite similar.
I used snappyHexMesh to refine the porous zone, and topoSet to create cell zones for porous block.
My problem is again, results (pressure drop across the porous zone) are not matching with the experiment data. The pressure drop created by using source term is 1/10 of the experiment value, no matter what D value you choose. The convergence plot is good, although T residuals is above 0.1.
Can someone explain what might cause this problem?
Thank you very much.
cissystef is offline   Reply With Quote
openfoam 2.1.x, porous boundary, porous domain
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 11:32
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
problem with pump as source term hari FLUENT 1 September 19, 2005 11:38
UDF Scalar Code: HT 1 Greg Perkins FLUENT 8 October 20, 2000 12:40
