June 1, 2015, 17:22 |
Incompatible dimensions for operation
Ruben Stap
Rep Power: 10 |
Hello everyone,
I am doing an school project in which i need to simulate an high speed fluid (1000m/s) entering a venturi tube. I want to simulate the pressure and speed in the venturi tube. I am doing this in the online-simulator Simscale which uses openFoam. At this high-speed density changes cannot be ignored, so i choose compressible in the options panel. Evertime I try to run the simulation I get the following error: Code:
[15] FOAM parallel run aborting [15] [16] [16] [16] --> FOAM FATAL ERROR: [16] incompatible dimensions for operation [U[0 1 -2 0 0 0 0] ] + [U[1 -2 -2 0 0 0 0] ] [16] [16] From function checkMethod(const fvMatrix<Type>&, const fvMatrix<Type>&) [16] in file at line 1332. [16] FOAM parallel run aborting [16] [17] [17] [17] --> FOAM FATAL ERROR: [17] incompatible dimensions for operation [U[0 1 -2 0 0 0 0] ] + [U[1 -2 -2 0 0 0 0] ] [17] [17] From function checkMethod(const fvMatrix<Type>&, const fvMatrix<Type>&) [17] in file at line 1332. [17] FOAM parallel run aborting [17] [31] #0 Foam::error::printStack(Foam::Ostream&)[13] #0 Foam::error::printStack(Foam::Ostream&)[20] [20] [20] --> FOAM FATAL ERROR: [20] incompatible dimensions for operation [U[0 1 -2 0 0 0 0] ] + [U[1 -2 -2 0 0 0 0] ] [20] [20] From function checkMethod(const fvMatrix<Type>&, const fvMatrix<Type>&) [20] in file at line 1332. [20] FOAM parallel run aborting [20] [4] #0 Foam::error::printStack(Foam::Ostream&)[22] [22] [22] --> FOAM FATAL ERROR: [22] incompatible dimensions for operation [U[0 1 -2 0 0 0 0] ] + [U[1 -2 -2 0 0 0 0] ] [22] [22] From function checkMethod(const fvMatrix<Type>&, const fvMatrix<Type>&) [22] in file at line 1332. [22] FOAM parallel run aborting [22] [21] #0 Foam::error::printStack(Foam::Ostream&)[24] [24] [24] --> FOAM FATAL ERROR: [24] incompatible dimensions for operation [U[0 1 -2 0 0 0 0] ] + [U[1 -2 -2 0 0 0 0] ] [24] [24] From function checkMethod(const fvMatrix<Type>&, const fvMatrix<Type>&) [24] in file at line 1332. [24] FOAM parallel run aborting [24] [25] [25] [25] --> FOAM FATAL ERROR: [25] incompatible dimensions for operation [U[0 1 -2 0 0 0 0] ] + [U[1 -2 -2 0 0 0 0] ] [25] [25] From function checkMethod(const fvMatrix<Type>&, const fvMatrix<Type>&) [25] in file at line 1332. [25] FOAM parallel run aborting [25] [26] [26] [26] --> FOAM FATAL ERROR: [26] incompatible dimensions for operation [U[0 1 -2 0 0 0 0] ] + [U[1 -2 -2 0 0 0 0] ] [26] [26] From function checkMethod(const fvMatrix<Type>&, const fvMatrix<Type>&) [26] in file at line 1332. [26] FOAM parallel run aborting [26] [27] [27] [27] --> FOAM FATAL ERROR: [27] incompatible dimensions for operation [U[0 1 -2 0 0 0 0] ] + [U[1 -2 -2 0 0 0 0] ] [27] [27] From function checkMethod(const fvMatrix<Type>&, const fvMatrix<Type>&) [27] in file at line 1332. [27] FOAM parallel run aborting [27] [28] [28] [28] --> FOAM FATAL ERROR: [28] incompatible dimensions for operation [U[0 1 -2 0 0 0 0] ] + [U[1 -2 -2 0 0 0 0] ] [28] [28] From function checkMethod(const fvMatrix<Type>&, const fvMatrix<Type>&) [28] in file at line 1332. [28] FOAM parallel run aborting [28] [29] [29] [29] --> FOAM FATAL ERROR: [29] incompatible dimensions for operation [U[0 1 -2 0 0 0 0] ] + [U[1 -2 -2 0 0 0 0] ] [29] [29] From function checkMethod(const fvMatrix<Type>&, const fvMatrix<Type>&) [29] in file at line 1332. [29] FOAM parallel run aborting [29] [30] [30] [30] --> FOAM FATAL ERROR: [30] incompatible dimensions for operation [U[0 1 -2 0 0 0 0] ] + [U[1 -2 -2 0 0 0 0] ] [30] [30] From function checkMethod(const fvMatrix<Type>&, const fvMatrix<Type>&) [30] in file at line 1332. [30] FOAM parallel run aborting [30] [7] #0 Foam::error::printStack(Foam::Ostream&)[23] #0 Foam::error::printStack(Foam::Ostream&)[0] [0] [0] --> FOAM FATAL ERROR: [0] incompatible dimensions for operation [U[0 1 -2 0 0 0 0] ] + [U[1 -2 -2 0 0 0 0] ] [0] [0] From function checkMethod(const fvMatrix<Type>&, const fvMatrix<Type>&) [0] in file at line 1332. [0] FOAM parallel run aborting [0] [1] [1] [1] --> FOAM FATAL ERROR: [1] incompatible dimensions for operation [U[0 1 -2 0 0 0 0] ] + [U[1 -2 -2 0 0 0 0] ] [1] [1] From function checkMethod(const fvMatrix<Type>&, const fvMatrix<Type>&) [1] in file at line 1332. [1] FOAM parallel run aborting [1] [14] #0 Foam::error::printStack(Foam::Ostream&)[3] [3] [3] --> FOAM FATAL ERROR: [3] incompatible dimensions for operation [U[0 1 -2 0 0 0 0] ] + [U[1 -2 -2 0 0 0 0] ] [3] [3] From function checkMethod(const fvMatrix<Type>&, const fvMatrix<Type>&) [3] in file at line 1332. [3] FOAM parallel run aborting [3] [18] #0 Foam::error::printStack(Foam::Ostream&)[19] #0 Foam::error::printStack(Foam::Ostream&)[29] #0 Foam::error::printStack(Foam::Ostream&)[30] #0 [17] #0 Foam::error::printStack(Foam::Ostream&)[20] #0 [27] #0 Foam::error::printStack(Foam::Ostream&)[16] #0 Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)[8] #0 Foam::error::printStack(Foam::Ostream&)[1] #0 Foam::error::printStack(Foam::Ostream&)[3] #0 Foam::error::printStack(Foam::Ostream&)[22] #0 [25] #0 [12] #0 Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)[24] #0 Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)[28] #0 Foam::error::printStack(Foam::Ostream&)[9] #0 Foam::error::printStack(Foam::Ostream&)[0] #0 Foam::error::printStack(Foam::Ostream&)[26] #0 Foam::error::printStack(Foam::Ostream&)[15] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [11] #1 Foam::error::abort() at ??:? [6] #1 Foam::error::abort() at ??:? [13] #1 Foam::error::abort() at ??:? [31] #1 Foam::error::abort() at ??:? [4] #1 Foam::error::abort() at ??:? [19] #1 Foam::error::abort() at ??:? [29] #1 Foam::error::abort() at ??:? [14] #1 Foam::error::abort() at ??:? [5] #1 Foam::error::abort() at ??:? [15] #1 Foam::error::abort() at ??:? [2] #1 Foam::error::abort() at ??:? [27] #1 Foam::error::abort() at ??:? [16] #1 Foam::error::abort() at ??:? [17] #1 Foam::error::abort() at ??:? [8] #1 Foam::error::abort() at ??:? [18] #1 Foam::error::abort() at ??:? [7] #1 Foam::error::abort() at ??:? [10] #1 Foam::error::abort() at ??:? [12] #1 Foam::error::abort() at ??:? [23] #1 Foam::error::abort() at ??:? [28] #1 Foam::error::abort() at ??:? [24] #1 Foam::error::abort() at ??:? [30] #1 Foam::error::abort() at ??:? [22] #1 Foam::error::abort() at ??:? [3] #1 Foam::error::abort() at ??:? [26] #1 Foam::error::abort() at ??:? [21] #1 Foam::error::abort() at ??:? [1] #1 Foam::error::abort() at ??:? [20] #1 Foam::error::abort() at ??:? [25] #1 Foam::error::abort() at ??:? [0] #1 Foam::error::abort() at ??:? [9] #1 Foam::error::abort() at ??:? [27] #2 at ??:? [17] #2 at ??:? [10] #2 at ??:? [26] #2 at ??:? [14] #2 at ??:? [11] #2 at ??:? [6] #2 at ??:? [31] #2 at ??:? [13] #2 at ??:? [4] #2 at ??:? [29] #2 at ??:? [15] #2 at ??:? [16] #2 at ??:? [18] #2 at ??:? [2] #2 at ??:? [30] #2 at ??:? [7] #2 at ??:? [3] #2 at ??:? [25] #2 at ??:? [12] #2 at ??:? [8] #2 at ??:? [22] #2 at ??:? [28] #2 at ??:? [19] #2 at ??:? [21] #2 at ??:? [23] #2 at ??:? [5] #2 at ??:? [9] #2 at ??:? [0] #2 at ??:? [1] #2 at ??:? [24] #2 at ??:? [20] #2 void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*)void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*)void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*)void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*)void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*)void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*)void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*)void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*)void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*)void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*)void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*)void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*)void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*)void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*)void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*)void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*)void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*)void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*)void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*)void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*)void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*)void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*)void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*)void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*)void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*)void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*)void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*)void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*)void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*)void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*)void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*)void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*) at ??:? [27] #3 at ??:? [2] #3 at ??:? [10] #3 at ??:? [6] #3 at ??:? [17] #3 at ??:? [31] #3 at ??:? [14] #3 at ??:? [0] #3 at ??:? [15] #3 at ??:? [4] #3 at ??:? [26] #3 at ??:? [11] #3 at ??:? [18] #3 at ??:? [29] #3 at ??:? [8] #3 at ??:? [16] #3 at ??:? [13] #3 at ??:? [7] #3 at ??:? [12] #3 at ??:? [25] #3 at ??:? [20] #3 at ??:? [9] #3 at ??:? [19] #3 at ??:? [30] #3 at ??:? [21] #3 at ??:? [5] #3 at ??:? [3] #3 at ??:? [28] #3 at ??:? [23] #3 at ??:? [24] #3 at ??:? [1] #3 at ??:? [22] #3 [10] at ??:? [10] #4 [26] at ??:? [26] #4 [6] at ??:? [6] #4 [27] at ??:? [27] #4 [31] at ??:? [31] #4 [17] at ??:? [17] #4 [5] at ??:? [5] #4 [2] at ??:? [2] #4 [15] at ??:? [15] #4 [11] at ??:? [11] #4 [4] at ??:? [4] #4 [14] at ??:? [14] #4 [30] at ??:? [30] #4 [8] at ??:? [8] #4 [3] at ??:? [3] #4 [29] at ??:? [29] #4 [0] at ??:? [0] #4 [18] at ??:? [18] #4 [7] at ??:? [7] #4 [13] at ??:? [13] #4 [12] at ??:? [12] #4 [1] at ??:? [1] #4 [20] at ??:? [20] #4 [16] at ??:? [16] #4 [19] at ??:? [19] #4 [25] at ??:? [25] #4 [9] at ??:? [9] #4 [21] at ??:? [21] #4 [28] at ??:? [28] #4 [23] at ??:? [23] #4 [22] at ??:? [22] #4 [24] at ??:? [24] #4 [5] at ??:? [5] #5 __libc_start_main [10] at ??:? [10] #5 __libc_start_main [6] at ??:? [6] #5 __libc_start_main[26] at ??:? [26] #5 __libc_start_main [11] at ??:? [11] #5 __libc_start_main[27] at ??:? [27] #5 __libc_start_main[25] at ??:? [25] #5 __libc_start_main[19] at ??:? [19] #5 __libc_start_main[31] at ??:? [31] #5 __libc_start_main[18] at ??:? [18] #5 __libc_start_main[17] at ??:? [17] #5 __libc_start_main[0] at ??:? [0] #5 __libc_start_main[15] at ??:? [15] #5 __libc_start_main[2] at ??:? [2] #5 __libc_start_main[30] at ??:? [30] #5 __libc_start_main[3] at ??:? [3] #5 __libc_start_main[28] at ??:? [28] #5 __libc_start_main[20] at ??:? [20] #5 __libc_start_main[4] at ??:? [4] #5 __libc_start_main[29] at ??:? [29] #5 __libc_start_main[12] at ??:? [12] #5 __libc_start_main[14] at ??:? [14] #5 __libc_start_main[1] at ??:? [1] #5 __libc_start_main[13] at ??:? [13] #5 __libc_start_main[16] at ??:? [16] #5 __libc_start_main[7] at ??:? [7] #5 __libc_start_main[8] at ??:? [8] #5 __libc_start_main in " [10] #6 [21] at ??:? [21] #5 __libc_start_main[23] at ??:? [23] #5 __libc_start_main[9] at ??:? [9] #5 __libc_start_main in " [19] #6 in " [5] #6 [22] at ??:? [22] #5 __libc_start_main[24] at ??:? [24] #5 __libc_start_main in " [26] #6 in " [6] #6 in " [11] #6 in " [27] #6 in " [15] #6 in " [31] #6 in " [17] #6 in " [25] #6 in " [2] #6 in " [0] #6 in " [30] #6 in " [18] #6 in " [3] #6 in " [28] #6 in " [29] #6 in " [14] #6 in " [12] #6 in " [20] #6 in " [1] #6 in " [16] #6 in " [7] #6 in " [4] #6 in " [8] #6 in " [13] #6 in " [21] #6 in " [23] #6 in " [9] #6 in " [24] #6 in " [22] #6 -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 3 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- [5] at ??:? [3] at ??:? [10] at ??:? [0] at ??:? [19] at ??:? [26] at ??:? [6] at ??:? [25] at ??:? [16] at ??:? [28] at ??:? [22] at ??:? [14] at ??:? [27] at ??:? [13] at ??:? [23] at ??:? [29] at ??:? [11] at ??:? [18] at ??:? [9] at ??:? [15] at ??:? [20] at ??:? [21] at ??:? [24] at ??:? [30] at ??:? [8] at ??:? [12] at ??:? [7] at ??:? [31] at ??:? [17] at ??:? -------------------------------------------------------------------------- mpirun has exited due to process rank 3 with on node exiting improperly. There are two reasons this could occur: 1. this process did not call "init" before exiting, but others in the job did. This can cause a job to hang indefinitely while it waits for all processes to call "init". By rule, if one process calls "init", then ALL processes must call "init" prior to termination. 2. this process called "init", but exited without calling "finalize". By rule, all processes that call "init" MUST call "finalize" prior to exiting or it will be considered an "abnormal termination" This may have caused other processes in the application to be terminated by signals sent by mpirun (as reported here). -------------------------------------------------------------------------- [:03895] 28 more processes have sent help message help-mpi-api.txt / mpi-abort [:03895] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages ×Free storag Code:
[17] incompatible dimensions for operation [U[0 1 -2 0 0 0 0] ] + [U[1 -2 -2 0 0 0 0] ] Does anyone have an idea? Kind-regards Ruben |
June 2, 2015, 02:23 |
Babak Gholami
Rep Power: 11 |
Do you by any chance initialize the solution with the potential flow? If yes, then just uncheck it and you are good to go.
June 12, 2015, 04:14 |
Solved
Ruben Stap
Rep Power: 10 |
Thanks to this, the error has dissappeared.
Incompatible dimensions for operation | pramodopen4foam | OpenFOAM | 10 | January 4, 2024 04:51 |
incompatible dimensions for operation | shakirbsm | OpenFOAM Running, Solving & CFD | 3 | November 3, 2014 05:50 |
Incompatible dimensions | sfigato | OpenFOAM Running, Solving & CFD | 2 | January 22, 2013 17:50 |
Incompatible dimensions.... | Amiga500 | OpenFOAM Running, Solving & CFD | 13 | June 1, 2012 07:20 |
incompatible dimensions for operation (rhoSimpleFoam) | dongest | OpenFOAM Running, Solving & CFD | 3 | July 19, 2011 04:51 |
