Solving a scalar field in a pure convection field |
December 5, 2023, 10:13 |
Mohammad Hossein
Rep Power: 2 |
Hello everyone,
I want to find a scalar (T) in a pure convection field which has a known velocity field. I've tried to use scalarTransportFoam (I'm supposed to solve the field with that solver) but I got this message: Code:
scalarTransportFoam has been superseded and replaced by the more general functions solver module executed by the foamRun application: foamRun -solver functions The solver specified by either the subSolver or if not present the solver entry in the controlDict is instantiated to provide the physical fields needed by the functionObjects. The scalarTransport functionObject is then instantiated from the functions entry in the controlDict and executed in a time-loop also controlled by entries in controlDict and the maxDeltaT() returned by the sub-solver. See: tutorials/modules/incompressibleFluid/pitzDailyScalarTransport Code:
FOAM FATAL ERROR: cannot find file "/home/smhk/CFD_P/0/p" From function virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::readStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 539. FOAM exiting What may I do? Thanks in advance (I'm completely new and I'm using Openfoam11) |
December 5, 2023, 11:46 |
Rep Power: 14 |
Interesting - in v8, you could get away without specifying a pressure field in the 0 folder, but you can't in v11 - it "needs" the p file to be present, but then presumably ignores it thereafter.
Solution: make sure you have a "dummy" p file in the 0 folder; I don't think that the values matter, so just put zero for the internal field and mirror the boundaries in your T file, eg: Code:
boundaryField { inlet { type zeroGradient; } outlet { type fixedValue; value uniform 0; } upperWall { type zeroGradient; } lowerWall { type zeroGradient; } frontAndBack { type empty; } } PS this may be worth entering a bug report ... |
December 5, 2023, 16:08 |
#3 | |
Mohammad Hossein
Rep Power: 2 |
Thank you. But this is also happening for other files is 0 directory: Code:
--> FOAM FATAL ERROR: cannot find file "/home/smhk/CFD_P/0/k" From function virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::readStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 539. CFD_P.zip P.S. My classmate have done it in openfoam 6 by scalarTransportFoam. |
December 6, 2023, 03:58 |
Rep Power: 14 |
Yes - it looks like it is trying to load all the components of the baseline solver before just carrying on with the scalar transport part, so i presume you'll have to have dummy versions of all of the files in the 0 folder. Or just use an earlier version of OpenFOAM - v8 works finr, as does v6 as you noted. Good luck.
pure convection, scalarfield |
chtMultiRegionSimpleFoam: maximum number of iterations excedeed. | Nkl | OpenFOAM Running, Solving & CFD | 19 | October 10, 2019 02:42 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 18:17 |
compressible flow in turbocharger | riesotto | OpenFOAM | 50 | May 26, 2014 01:47 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
