June 2, 2017, 13:37 |
sclsVOFFoam
#1 | ||
Masoumeh Gharaati
Rep Power: 9 |
Dear all
I 'm using sclsVOFFoam solver. http://www.tfd.chalmers.se/~hani/kur...ankarMenon.pdf I 'm modeling droplet impact into liquid layer. the liquid is water and the gas is air. When I 'm using the Quote:
June 20, 2017, 22:59 |
Nguyen Duy Trong
Rep Power: 12 |
"Foam::symGaussSeidelSmoother::smooth(Foam::wo rd const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:? "
I think there is problem of variable name, you should keep same variable name. On the other hand, you simply change value of the variable you want to change |
June 22, 2017, 11:51 |
Masoumeh Gharaati
Rep Power: 9 |
I just changed the value of variables. I didn't change any name.
June 22, 2017, 12:27 |
#4 | |
Hi all,
@mgharaati Your solution diverges. Why your solution diverges? It is difficult to say from what you have posted. This Quote:
June 26, 2017, 15:49 |
Masoumeh Gharaati
Rep Power: 9 |
It 's related to Courant number. I check the log file and Courant number got too much. Then, I tried to keep Courant number under 0.1 but it didn't work too.
June 28, 2017, 03:05 |
Nguyen Duy Trong
Rep Power: 12 |
I don't think it work by changing of variable's value. I mean you change the name of variable, you should look into the createFields file to see how your code read variable name.
June 28, 2017, 03:07 |
Nguyen Duy Trong
Rep Power: 12 |
please upload your transportProperties file in constant folder
July 6, 2017, 05:25 |
#9 | |
Nguyen Duy Trong
Rep Power: 12 |
Maybe there are another reason for your errors. Sorry about that |
September 30, 2018, 01:17 |
#10 |
krishna kant
Rep Power: 10 |
Hi All
I am also solving sclsVOFFoamsf and getting a similar error like shown in the original post. It is coming from the reinitialization step. Can anyone guide what could possibly went wrong? solve the reinitialization equation #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? at sigaction.c:? #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:? #5 ? at ??:? #6 __libc_start_main at ??:? #7 ? at ??:? Floating point exception (core dumped) I have individually look on the output of all individual values involved like psi, grad(psi) deltaTau they all look fine. The boundary condition is cyclic for all variables. |
September 30, 2018, 02:32 |
#11 | |
Masoumeh Gharaati
Rep Power: 9 |
Hi
I am afraid to say that I couldn't solve the problem and I still get the same error. Quote:
October 31, 2018, 21:53 |
#12 | |
Huang Xianbei
Rep Power: 13 |
The problem remains in the solveLSFunction.H: psi = psi + psi0/mag(psi0)... psi can be zero so that the divide operator will lead to divergence. Change: psi = psi + psi0/max(mag(psi0),VSMALL) This can avoid the error. However, I still can not get a converged solution for my case. The calculation crashed after a few iterations Last edited by huangxianbei; November 1, 2018 at 21:20. |
clsvof, viscosity |
