error before the first iteration of komegaSST
Old   August 31, 2015, 13:37
Default error before the first iteration of komegaSST
RacMat
rvl565 is on a distinguished road
Hi everyone,
I am running a flat plate Turbulent BL using simpleFoam and i get the following error. Could anyone help me out with this? Thanks!
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model kOmegaSST
kOmegaSSTCoeffs
alphaK1 0.85;
alphaK2 1;
alphaOmega1 0.5;
alphaOmega2 0.856;
gamma1 0.555556;
gamma2 0.44;
beta1 0.075;
beta2 0.0828;
betaStar 0.09;
a1 0.31;
b1 1;
c1 10;
F3 false;
No finite volume options present
SIMPLE: no convergence criteria found. Calculations will run for 100000 steps.
Starting time loop
Time = 1
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#4 ? at ??:?
#5 ? at ??:?
#6 ? at ??:?
#7 ? at ??:?
#8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#9 ? at ??:?
Floating point exception (core dumped)
rvl565 is offline   Reply With Quote
Old   August 31, 2015, 15:07
Troy Snyder
tas38 is on a distinguished road
It appears that you may be missing parts of the files within the system/ directory. Posting the controlDict, fvSchemes, and fvSolution files may prove helpful.
tas38 is offline   Reply With Quote
Old   August 31, 2015, 19:59
Default controlDict fvSchemes fvSolution files
RacMat
Hi, i have attached the 3 files. I took them from the motor bike case
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
libs ("libmyDDESInflowBC_vel.so");
application simpleFoam;
startFrom latestTime;
startTime 0;
stopAt endTime;
endTime 100000;
deltaT 1;
writeControl timeStep;
writeInterval 100;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
fvSchemes:
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
//grad(U) cellLimited Gauss linear 1;
divSchemes
default none;
div(phi,U) bounded Gauss linear;
div(phi,k) bounded Gauss upwind;
div(phi,omega) bounded Gauss upwind;
div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p;
Phi;
fvSolution
solvers
p
solver GAMG;
tolerance 1e-7;
relTol 0.01;
smoother GaussSeidel;
nPreSweeps 0;
nPostSweeps 2;
cacheAgglomeration on;
agglomerator faceAreaPair;
nCellsInCoarsestLevel 10;
mergeLevels 1;
Phi
$p;
U
solver smoothSolver;
tolerance 1e-8;
relTol 0.1;
nSweeps 1;
k
tolerance 1e-8;
relTol 0.1;
nSweeps 1;
omega
tolerance 1e-8;
relTol 0.1;
nSweeps 1;
SIMPLE
nNonOrthogonalCorrectors 0;
potentialFlow
nNonOrthogonalCorrectors 10;
relaxationFactors
fields
p 0.3;
equations
U 0.7;
k 0.7;
omega 0.7;
cache
grad(U);
first iteration error, openfoam, simplefoam
GPU - GeForce GTX Titan Black? frode86 Hardware 11 August 8, 2016 22:36
Hardware-Configuration for Fluent HPC-Pack (8x) JohHaas Hardware 9 March 3, 2015 13:25
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 09:02
Parallel runs slower with MTU=9000 than MTU=1500 Javier Larrondo FLUENT 0 October 28, 2007 22:30
Heat exchanger problem chiseung FLUENT 16 October 20, 2001 04:36
