April 11, 2015, 14:42 |
simpleFoam 3D case: crashes after 7 cycles
alvaro
Rep Power: 11 |
I am beginner in the field of CFD and OpenFOAM. I need some help or advice with my case. Basically I have used the PitzDaily default case of OpenFOAM tutorials but with a new 3D geometry instead of 2D and new boundary values of pressure and velocity. These are the values of p, U, k and epsilon: Code:
dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { walls { type zeroGradient; } inlet { type fixedValue; value uniform 200; } outlet { type fixedValue; value uniform 0; } } Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { walls { type fixedValue; value uniform (0 0 0); } inlet { type fixedValue; value uniform (0 0 0); } outlet { type zeroGradient; } } Code:
dimensions [0 2 -2 0 0 0 0]; internalField uniform 0.375; boundaryField { walls { type kqRWallFunction; value uniform 0.375; } inlet { type fixedValue; value uniform 0.375; } outlet { type zeroGradient; } } Code:
dimensions [0 2 -3 0 0 0 0]; internalField uniform 14.855; boundaryField { walls { type epsilonWallFunction; value uniform 14.855; } inlet { type fixedValue; value uniform 14.855; } outlet { type zeroGradient; } } Code:
#0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/simpleFoam" #8 in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/simpleFoam" #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #10 in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/simpleFoam" by the by I would like upload a jpg file of residual values from my desktop but I don't know how do it. |
April 11, 2015, 17:15 |
#2 | |
Troy Snyder
Rep Power: 18 |
either divergence or there is an error writing and output file. Based on what you posted it appears that the latter is more likely. Also, please post your solver settings files if they differ from the pitzDaily tutorial. |
April 12, 2015, 06:06 |
alvaro
Rep Power: 11 |
Here is the output log file:
alvaro@AlvaroPC:~/OpenFOAM/run/pitzDaily$ simpleFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.3.0-f5222ca19ce6 Exec : simpleFoam Date : Apr 12 2015 Time : 11:44:53 Host : "AlvaroPC" PID : 2859 Case : /home/alvaro/OpenFOAM/run/pitzDaily nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting RAS turbulence model kEpsilon kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; sigmaEps 1.3; } No finite volume options present SIMPLE: convergence criteria field p tolerance 0.01 field U tolerance 0.001 field "(k|epsilon|omega)" tolerance 0.001 Starting time loop streamLine streamLines: automatic track length specified through number of sub cycles : 5 Time = 1 smoothSolver: Solving for Ux, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0384349, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0, Final residual = 0, No Iterations 0 GAMG: Solving for p, Initial residual = 1, Final residual = 0.095593, No Iterations 1 time step continuity errors : sum local = 52.102, global = -0.56931, cumulative = -0.56931 smoothSolver: Solving for epsilon, Initial residual = 0.988297, Final residual = 0.000247036, No Iterations 1 bounding epsilon, min: -3.70276 max: 188967 average: 41.0059 smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.0800895, No Iterations 1 ExecutionTime = 0.32 s ClockTime = 0 s Time = 2 smoothSolver: Solving for Ux, Initial residual = 0.645571, Final residual = 0.0636477, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 0.443996, Final residual = 0.00986204, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.691369, Final residual = 0.0653874, No Iterations 1 GAMG: Solving for p, Initial residual = 0.999027, Final residual = 0.0763541, No Iterations 4 time step continuity errors : sum local = 31.7509, global = 1.89734, cumulative = 1.32803 smoothSolver: Solving for epsilon, Initial residual = 0.695385, Final residual = 2.08712e-05, No Iterations 1 smoothSolver: Solving for k, Initial residual = 0.919585, Final residual = 0.0823362, No Iterations 2 ExecutionTime = 0.45 s ClockTime = 0 s Time = 3 smoothSolver: Solving for Ux, Initial residual = 0.440654, Final residual = 0.0427516, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 0.560425, Final residual = 0.0419665, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 0.410988, Final residual = 0.0349522, No Iterations 1 GAMG: Solving for p, Initial residual = 0.642045, Final residual = 0.063517, No Iterations 2 time step continuity errors : sum local = 38.5966, global = -9.32056, cumulative = -7.99253 smoothSolver: Solving for epsilon, Initial residual = 0.224899, Final residual = 3.99216e-06, No Iterations 1 bounding epsilon, min: -13464.6 max: 7.90228e+06 average: 9149.1 smoothSolver: Solving for k, Initial residual = 0.474471, Final residual = 0.045027, No Iterations 2 ExecutionTime = 0.57 s ClockTime = 0 s Time = 4 smoothSolver: Solving for Ux, Initial residual = 0.773657, Final residual = 0.050837, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.600411, Final residual = 0.0464153, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.733712, Final residual = 0.0562857, No Iterations 2 GAMG: Solving for p, Initial residual = 0.840831, Final residual = 0.0582094, No Iterations 1 time step continuity errors : sum local = 321.621, global = 81.3235, cumulative = 73.3309 smoothSolver: Solving for epsilon, Initial residual = 0.740998, Final residual = 9.77163e-05, No Iterations 1 bounding epsilon, min: -984.549 max: 8.36834e+08 average: 362259 smoothSolver: Solving for k, Initial residual = 0.949549, Final residual = 0.0942416, No Iterations 2 ExecutionTime = 0.69 s ClockTime = 1 s Time = 5 smoothSolver: Solving for Ux, Initial residual = 0.732108, Final residual = 0.0686708, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 0.476365, Final residual = 0.0449628, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 0.446049, Final residual = 0.0407226, No Iterations 1 GAMG: Solving for p, Initial residual = 0.840493, Final residual = 0.0792588, No Iterations 1 time step continuity errors : sum local = 234.221, global = 66.9484, cumulative = 140.279 smoothSolver: Solving for epsilon, Initial residual = 0.228923, Final residual = 1.06908e-06, No Iterations 1 bounding epsilon, min: -3.43861e+07 max: 6.90822e+10 average: 4.3941e+07 smoothSolver: Solving for k, Initial residual = 0.452072, Final residual = 0.0196315, No Iterations 2 bounding k, min: -485.765 max: 3.29082e+06 average: 8562.43 ExecutionTime = 0.81 s ClockTime = 1 s Time = 6 smoothSolver: Solving for Ux, Initial residual = 0.278225, Final residual = 0.0234514, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 0.240453, Final residual = 0.0144066, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 0.359935, Final residual = 0.0329614, No Iterations 1 GAMG: Solving for p, Initial residual = 0.916368, Final residual = 0.0709018, No Iterations 1 time step continuity errors : sum local = 6564.03, global = 184.483, cumulative = 324.762 smoothSolver: Solving for epsilon, Initial residual = 0.013258, Final residual = 0.000666225, No Iterations 1 bounding epsilon, min: -2.72697e+08 max: 1.56504e+13 average: 4.78779e+09 smoothSolver: Solving for k, Initial residual = 0.4201, Final residual = 0.0274674, No Iterations 1 bounding k, min: -40309.9 max: 1.33333e+09 average: 716884 ExecutionTime = 0.93 s ClockTime = 1 s Time = 7 smoothSolver: Solving for Ux, Initial residual = 0.0337342, Final residual = 0.00201148, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 0.0468805, Final residual = 0.00289706, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 0.0158243, Final residual = 0.000456582, No Iterations 1 GAMG: Solving for p, Initial residual = 0.110785, Final residual = 0.00775269, No Iterations 2 time step continuity errors : sum local = 2.54362e+14, global = 4.21581e+11, cumulative = 4.21581e+11 smoothSolver: Solving for epsilon, Initial residual = 1, Final residual = 0.0349246, No Iterations 3 smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.0851641, No Iterations 1 ExecutionTime = 1.05 s ClockTime = 1 s Time = 8 smoothSolver: Solving for Ux, Initial residual = 0.515451, Final residual = 0.0207056, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.722785, Final residual = 0.0488147, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 0.818181, Final residual = 0.0520304, No Iterations 1 GAMG: Solving for p, Initial residual = 0.999684, Final residual = 0.0983319, No Iterations 5 time step continuity errors : sum local = 2.51385e+14, global = -2.99544e+12, cumulative = -2.57385e+12 smoothSolver: Solving for epsilon, Initial residual = 0.0130558, Final residual = 8.86302e-16, No Iterations 1 bounding epsilon, min: -1.21842e+35 max: 4.92931e+40 average: 8.18944e+36 smoothSolver: Solving for k, Initial residual = 0.5328, Final residual = 0.0426716, No Iterations 1 bounding k, min: -4.2741e+20 max: 5.74832e+36 average: 1.05138e+33 ExecutionTime = 1.2 s ClockTime = 1 s Time = 9 smoothSolver: Solving for Ux, Initial residual = 0.0524346, Final residual = 0.00248475, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 0.22741, Final residual = 0.0195766, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 0.010153, Final residual = 0.000734547, No Iterations 1 GAMG: Solving for p, Initial residual = 0.00514794, Final residual = 0.000331134, No Iterations 2 time step continuity errors : sum local = 3.5522e+33, global = -1.27833e+31, cumulative = -1.27833e+31 smoothSolver: Solving for epsilon, Initial residual = 1, Final residual = 0.0524548, No Iterations 29 smoothSolver: Solving for k, Initial residual = 3.38676e-07, Final residual = 3.38676e-07, No Iterations 0 ExecutionTime = 1.35 s ClockTime = 1 s Time = 10 smoothSolver: Solving for Ux, Initial residual = 0.646186, Final residual = 0.0522116, No Iterations 40 smoothSolver: Solving for Uy, Initial residual = 0.56795, Final residual = 0.0301241, No Iterations 41 smoothSolver: Solving for Uz, Initial residual = 0.529712, Final residual = 0.0287035, No Iterations 38 #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/simpleFoam" #8 in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/simpleFoam" #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #10 in "/opt/openfoam230/platforms/linux64GccDPOpt/bin/simpleFoam" Floating point exception (core dumped) alvaro@AlvaroPC:~/OpenFOAM/run/pitzDaily$ And when you say solver settings files you mean ControlDict file, isn't it? Here is, but I didn't modified anything Code:
FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application simpleFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 1000; deltaT 1; writeControl timeStep; writeInterval 50; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; functions { streamLines { type streamLine; // Where to load it from (if not already in solver) functionObjectLibs ("libfieldFunctionObjects.so"); // Output every outputControl outputTime; // outputInterval 10; setFormat vtk; //gnuplot;//xmgr;//raw;//jplot;//csv;//ensight; // Velocity field to use for tracking. UName U; // Tracked forwards (+U) or backwards (-U) trackForward true; // Names of fields to sample. Should contain above velocity field! fields (p k U); // Steps particles can travel before being removed lifeTime 10000; // Number of steps per cell (estimate). Set to 1 to disable subcycling. nSubCycle 5; // Cloud name to use cloudName particleTracks; // Seeding method. See the sampleSets in sampleDict. seedSampleSet uniform; //cloud;//triSurfaceMeshPointSet; uniformCoeffs { type uniform; axis x; //distance; start (-0.0205 0.001 0.00001); end (-0.0205 0.0251 0.00001); nPoints 10; } } } |
April 12, 2015, 13:10 |
Troy Snyder
Rep Power: 18 |
Your solution is diverging.
I would suggest running checkMesh to look for mesh issues. Also, I don't believe you can specify static pressure on both the inlet and the outlet. I would change the inlet to total pressure. |
April 12, 2015, 14:41 |
alvaro
Rep Power: 11 |
Referred to the mesh, not seen nothing unusual, except some non-orthogonal faces:
alvaro@AlvaroPC:~/OpenFOAM/run/pitzDaily2$ checkMesh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.3.0-f5222ca19ce6 Exec : checkMesh Date : Apr 12 2015 Time : 20:11:08 Host : "AlvaroPC" PID : 3402 Case : /home/alvaro/OpenFOAM/run/pitzDaily2 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 5865 faces: 47633 internal faces: 39075 cells: 21677 faces per cell: 4 boundary patches: 3 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 0 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 21677 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology walls 8313 4219 ok (non-closed singly connected) inlet 84 84 ok (non-closed singly connected) outlet 161 101 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-1.66857 -0.201602 -1.67331) (2.51658 2.87607 1.67331) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (-1.95172e-16 1.45104e-16 -1.42852e-16) OK. Max cell openness = 1.73452e-15 OK. Max aspect ratio = 348.834 OK. Minimum face area = 2.90131e-08. Maximum face area = 0.0227372. Face area magnitudes OK. Min volume = 2.83827e-11. Max volume = 0.00110686. Total volume = 2.07994. Cell volumes OK. Mesh non-orthogonality Max: 89.4051 average: 22.6028 *Number of severely non-orthogonal (> 70 degrees) faces: 57. Non-orthogonality check OK. <<Writing 57 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. Max skewness = 1.82439 OK. Coupled point location match (average 0) OK. Mesh OK. End The case that I am trying to solver is a simulation of a 3D nozzle that inject diesel fuel to cylinder. The velocity is unknown, but at the entry and exit is depreciated. All that is known is the inlet and outlet pressure. The real values are 350 bar at inlet and 1 bar at outlet. How would you set the BC's for this case? Thanks. |
April 12, 2015, 16:34 |
Troy Snyder
Rep Power: 18 |
Here is an example for setting a totalPressure boundary (in p file):
injInlet { type totalPressure; U U; gamma 1.0; p0 uniform 111.111; } |
April 13, 2015, 07:02 |
alvaro
Rep Power: 11 |
I tried everything you advised me, but the problem still appearing. Even so, thank you for answers and advice me. Now I am going to try make a new mesh completly structured, without non-orthogonal faces. I'll let you know if it works. Regards. |
May 29, 2015, 08:53 |
#8 | |
Rep Power: 12 |
did you try with a new mesh? Did it work? Best regards, Kate |
May 30, 2015, 05:52 |
#9 | |
alvaro
Rep Power: 11 |
I tried it with a new mesh better quality, but still doesn't work.. and I don't know why Now I'm working with cavitatingFoam tutorial "throttle" and the same mesh and the same condition. For now the results look good for a pressure driven flow and the cavitation phenomena. Regards |
May 30, 2015, 06:06 |
#10 | |
Rep Power: 12 |
did your new mesh pass all the tests from checkMesh? Another topic, I am not familiar with your type of BCs (pressure assigned at inlet AND outlet). I would look at this again. Also, I would recommend intitializing your case with turbulence switched off. Regarding your work with the "throttle" settings. You said it looks good. Congratulations! Can you give us a bit more information on this? Does it converge, is your problem solved then? Best regards, Kate P.S.: When tas38 asked about the solver settings, I think he meant the fvSolution file in the system directory. |
June 2, 2015, 05:03 |
#11 | |
alvaro
Rep Power: 11 |
Sorry for my late reply. Yes, the new mesh pass checkMesh without problem (it's a very simple geometry of a nozzle made with blockMesh) Regarding the pressure and velocity condition: 0/p Code:
dimensions [1 -1 -2 0 0]; internalField uniform 1e5; boundaryField { frontback { type empty; } inlet { type totalPressure; U U; phi phiv; rho rho; psi none; gamma 1; p0 uniform 150e5; } outlet { type fixedValue; value uniform 1e5; } nozzleWall { type zeroGradient; } fixedWall { type zeroGradient; } } Code:
{ frontback { type empty; } inlet { type pressureInletOutletVelocity; value uniform (0 0 0); } outlet { type inletOutlet; inletValue uniform (0 0 0); value uniform (0 0 0); } nozzleWall { type fixedValue; value uniform (0 0 0); } fixedWall { type fixedValue; value uniform (0 0 0); } } About the cavitating problem, I still have problem with convergence. The case crash a few minutes to start. The residuals look fine, the only strange thing I see is highlighted in black below. Code:
DILUPBiCG: Solving for rho, Initial residual = 3.65416e-05, Final residual = 4.73255e-11, No Iterations 1 max-min rho: 72391.2 -6.84908 max-min gamma: 1 0 DILUPBiCG: Solving for Ux, Initial residual = 0.00712085, Final residual = 1.85145e-11, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.00714144, Final residual = 1.855e-11, No Iterations 2 max(U) 1.53422e+65 GAMG: Solving for p, Initial residual = 1.99619e-05, Final residual = 3.99114e-18, No Iterations 1 Predicted p max-min : 4.9197e+10 -9.75485e+126 max-min gamma: 1 0 Phase-change corrected p max-min : 4.9197e+10 -9.75485e+126 max(U) 1.53422e+65 GAMG: Solving for p, Initial residual = 5.07469e-05, Final residual = 5.54335e-18, No Iterations 1 Predicted p max-min : 4.9197e+10 -9.75478e+126 max-min gamma: 1 0 Phase-change corrected p max-min : 4.9197e+10 -9.75478e+126 max(U) 1.53422e+65 DILUPBiCG: Solving for omega, Initial residual = 0.0591393, Final residual = 2.52565e-12, No Iterations 2 #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #4 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #5 Foam::fvMatrix<double>::solve() in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/cavitatingFoam" #6 Foam::incompressible::RASModels::kOmegaSST::correct() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so" #7 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/cavitatingFoam" #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #9 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/cavitatingFoam" Floating point exception (core dumped) I show the fvSolution settings if the problem was there: Code:
solvers { rho { solver PBiCG; preconditioner DILU; tolerance 1e-08; relTol 0.1; } rhoFinal { solver PBiCG; preconditioner DILU; tolerance 1e-08; relTol 0; } p { solver GAMG; tolerance 0; relTol 0.1; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } pFinal { $p; tolerance 1e-08; relTol 0; } "(U|k|omega)" { solver PBiCG; preconditioner DILU; tolerance 1e-08; relTol 0.1; } "(U|k|omega)Final" { solver PBiCG; preconditioner DILU; tolerance 1e-08; relTol 0; } } PIMPLE { nCorrectors 3; nNonOrthogonalCorrectors 0; } Thanks and regards, Alvaro. |
June 3, 2015, 05:18 |
#12 |
Al_th
Rep Power: 11 |
Hi alvariten,
I notice something strange about your boundary condition. Even before being interested in the mesh, or the laminar/turbulent scheme. You impose a pressure at the inlet, but you are saying that the velocity is fixed at (0 0 0). But isn't your goal to let fluid go through the inlet ? If so, the velocity cannot be an uniform fixed value (0 0 0) and I would recommand you to change the U field for the inlet to type zeroGradient; |
June 3, 2015, 19:43 |
#13 |
alvaro
Rep Power: 11 |
Hi Al_th,
I'm still learning in field of OpenFoam so I'm grateful that you advice me. What you propose makes sense. I have tried with zeroGradient at inlet and outlet but the error still appears. Yes, my goal is impose varying pressure values over time (with uniformTotalPressrue) at inlet and fixed values at outlet with the purpose to get the mass flow through the output. The velocity is unknown so the best option is to set type zeroGradient. I have no idea where is the mistake but I am struck by the warning message "FOAM Warning : From function Time:perator++()". This is related to the Co number and it means the time precision is increase while deltaT become too small, isn't it? Could be this the reason of the problem? Code:
GAMG: Solving for p, Initial residual = 0.000137488, Final residual = 4.00266e-17, No Iterations 1 Predicted p max-min : 2.17415e+09 -704709 max-min gamma: 1 0 Phase-change corrected p max-min : 2.17415e+09 29.1545 max(U) 1.17523e+106 GAMG: Solving for p, Initial residual = 0.000160614, Final residual = 4.01508e-17, No Iterations 1 Predicted p max-min : 2.17415e+09 -773613 max-min gamma: 1 0 Phase-change corrected p max-min : 2.17415e+09 29.1545 max(U) 1.17523e+106 GAMG: Solving for p, Initial residual = 0.000135725, Final residual = 4.05313e-17, No Iterations 1 Predicted p max-min : 2.17415e+09 -878458 max-min gamma: 1 0 Phase-change corrected p max-min : 2.17415e+09 29.1545 max(U) 1.17523e+106 ExecutionTime = 372.39 s ClockTime = 446 s phiv Courant Number mean: 6.053e-06 max: 0.550988 acoustic max: 3.23685e-103 deltaT = 1.86875e-112 --> FOAM Warning : From function Time::operator++() in file db/Time/Time.C at line 1010 Increased the timePrecision from 1339 to 1340 to distinguish between timeNames at time 3.95078e-06 Time = 3.950780097946136277327518204760536946196225471794605255126953125e-06 DILUPBiCG: Solving for rho, Initial residual = 3.68513e-05, Final residual = 1.19211e-09, No Iterations 2 max-min rho: 3784.75 -1.81282 max-min gamma: 1 0 DILUPBiCG: Solving for Ux, Initial residual = 0.00088791, Final residual = 2.56648e-11, No Iterations 3 #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPO What else I can do? Regards. |
June 3, 2015, 20:04 |
#14 |
alvaro
Rep Power: 11 |
By the by, I would like to change the title of the thread because it no longer reflects well the topic to solve but I don't know how...
June 4, 2015, 03:51 |
#15 |
Al_th
Rep Power: 11 |
Dear alvariten,
Don't worry, I'm also an Openfoam newbie (2/3 months only) Yes, what you are saying is true, it looks like your Courant number blows up, and that the dynamic delatT (I am assuming you are using adjustTimeStep in your controlDict file) is getting smaller and smaller in order to respect your maxCo condition. From what I've learned, if the Courant number blows up, it is not always (in my case, pretty much never) a problem of actually setting up deltaT. Especially when you use adjustTimeStep that is keeping an ideal deltaT at all time (until it blows up). What I am suggesting here, is that when the problem happens, it causes the Courant number to blow up, but the problem itself is caused by something else (non physical boundary conditions have a nice tendency to make everything crash pretty fast). Could you attach your case to the post so we can try it out ? PS : In the meantime, what you could do is to try to reduce the pressure gradient (set the inlet pressure to something really close to the outlet, see if it crashes or of the solution seems to converge, and increase it gradually. Last edited by al_th; June 4, 2015 at 05:03. |
June 4, 2015, 06:40 |
#16 |
alvaro
Rep Power: 11 |
Dear Al_th,
Here I show more details about the case: - Geometry mesh (2D -> 2 input and 1 output) (I've changed mesh) - checkMesh log: Code:
Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 57460 internal points: 0 faces: 112969 internal faces: 55641 cells: 28080 boundary patches: 5 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 27958 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 122 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology inlet 60 124 ok (non-closed singly connected) outlet 72 146 ok (non-closed singly connected) nozzleWall 218 438 ok (non-closed singly connected) fixedWall 818 1640 ok (non-closed singly connected) frontback 56160 57460 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.00081733 0 -1e-05) (0.00081733 0.00202762 1e-05) Mesh (non-empty, non-wedge) directions (1 1 0) Mesh (non-empty) directions (1 1 0) All edges aligned with or perpendicular to non-empty directions. Boundary openness (-4.75227e-18 2.00089e-17 2.02558e-15) OK. Max cell openness = 5.78434e-16 OK. Max aspect ratio = 7.27553 OK. Minumum face area = 1.38739e-12. Maximum face area = 7.66506e-10. Face area magnitudes OK. Min volume = 2.77478e-17. Max volume = 1.53301e-14. Total volume = 1.8426e-11. Cell volumes OK. Mesh non-orthogonality Max: 47.2926 average: 12.1634 Non-orthogonality check OK. Face pyramids OK. Max skewness = 3.41278 OK. Coupled point location match (average 0) OK. Mesh OK. End cavitatingFoam log file - Numerical settings: controlDict fvScheme fvSolution - BC's from 0 folder: p pinlet file Code:
( (0 3410000) (0.00042 18130000) ); (the case run in laminar model, but these are the set values for LESModel) k nuSgs And it's all I think. If I have leave something, let me know. Thanks for the interest. Regards. Last edited by alvariten; June 8, 2015 at 13:51. |
June 8, 2015, 04:59 |
#17 | |
Rep Power: 12 |
I am afraid I cannot help you here. Nethertheless I have two remarks: 1) I think the max-min rho etc. outputs are no problem per se. But regarding the values I can't judge them because I'm not familiar with these types of simulations. 2) I would try to run the calculation with turbulence turned off. This way you can be sure the problem's not turbulence related. Keep us updated, Kate |
June 8, 2015, 10:31 |
#18 |
Al_th
Rep Power: 11 |
Dear Alvariten.
I do not see anything unusual in what you gave me (Note that in your last post, half your links were pointing on the controlDict file !) Could you upload the full case so I can investigate ? |
June 8, 2015, 14:00 |
Nozzle 2D cavitaingFoam divergence
#19 | |
alvaro
Rep Power: 11 |
I've fixed it! PD: I would like to change the main thread title (to "Nozzle 2D cavitatingFoam divergence" ) I think it's the right thing and it describes current topic better. But I don't find the way to do it. Is it possible to change by myself or is an Administrator/Moderator who has to do it? Regards. |
July 2, 2015, 03:10 |
#20 |
sagar gurnani
Rep Power: 10 |
Dear Alvariten,
How did you fixed your divergence problem.. could you please explain.. I am facing similar issues. Thanks |
cavitatingfoam, divergence |
simpleFoam: case only converges with most div schemes set to upwind | buffi | OpenFOAM Running, Solving & CFD | 7 | November 11, 2013 07:54 |
How to copy the simpleFoam case to turboFoam | sivakumar | OpenFOAM Pre-Processing | 5 | November 18, 2009 02:49 |
snappyMesh Motor Bike case for simpleFoam solver | s.sivakumar | OpenFOAM Running, Solving & CFD | 0 | July 22, 2009 08:00 |
Restart of case crashes | feijooos | OpenFOAM Running, Solving & CFD | 0 | July 21, 2009 11:04 |
Running a case with simpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 4 | March 28, 2008 07:13 |
