June 27, 2014, 10:22 |
Foam::error::PrintStack in GAMGSolver
David AKNIN
Hello everyone,
I'm trying to simulate a wavemaker with the interFoam solver (air phase + water phase) considering a laminar flow. I have implemented my own input kinematics based on the uniform velocity profile of a piston-type wavemaker. My mesh is a 3m long wave flume, with a water depth of 0.6m. The resolution is 5cm, except around the free surface where I had to refine the mesh to capture the free surface position accurately (resolution of 2mm). I also had to refine the mesh at the wavemaker to account for the local high velocity gradients due to the no-slip boundary condition an the paddle (resolution of 5mm). My simulation always crashes at the same time (t = 0.40s). I didn't use adaptative time-stepping, and reducing the time step doesn't avoid the crash. Also, the courant number doesn't go up before it crashes. My boundary conditions are: U: inlet { type waveVelocity; refValue uniform ( 0 0 0 ); refGradient uniform ( 0 0 0 ); valueFraction uniform 1; value uniform ( 0 0 0 ); } bottom { type fixedValue; value uniform ( 0 0 0 ); } outlet { type fixedValue; value uniform ( 0 0 0 ); } atmosphere { type pressureInletOutletVelocity; value uniform ( 0 0 0 ); } front { type slip; } back { type slip; } p_rgh: front { type zeroGradient; } back { type zeroGradient; } bottom { type zeroGradient; } inlet { type zeroGradient; } outlet { type zeroGradient; } atmosphere { type totalPressure; rho none; psi none; gamma 1; p0 uniform 0; value uniform 0; } alpha1: inlet { type waveAlpha; refValue uniform 0; refGrad uniform 0; valueFraction uniform 1; value uniform 0; } bottom { type zeroGradient; } outlet { type zeroGradient; } atmosphere { type inletOutlet; inletValue uniform 0; value uniform 0; } front { type zeroGradient; } back { type zeroGradient; } Here are the last 3 iterations before it crashes, could anyone help ? MULES: Solving for alpha1 Phase-1 volume fraction = 0.884502 Min(alpha1) = -0.000918702 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.884501 Min(alpha1) = -0.000975817 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.884501 Min(alpha1) = -0.00102995 Max(alpha1) = 1 Relaxing time: 0.04 s DILUPBiCG: Solving for Ux, Initial residual = 0.000459341, Final residual = 9.65422e-15, No Iterations 4 DILUPBiCG: Solving for Uy, Initial residual = 0.000712516, Final residual = 2.7008e-14, No Iterations 4 DILUPBiCG: Solving for Uz, Initial residual = 0.00157154, Final residual = 3.37197e-14, No Iterations 4 GAMG: Solving for p_rgh, Initial residual = 0.00131087, Final residual = 8.49745e-13, No Iterations 26 GAMG: Solving for p_rgh, Initial residual = 5.6643e-05, Final residual = 8.0606e-13, No Iterations 19 GAMG: Solving for p_rgh, Initial residual = 5.58024e-06, Final residual = 9.06201e-13, No Iterations 15 GAMG: Solving for p_rgh, Initial residual = 3.8308e-07, Final residual = 3.82669e-13, No Iterations 12 time step continuity errors : sum local = 2.65472e-16, global = -1.89997e-17, cumulative = -1.20753e-15 GAMG: Solving for p_rgh, Initial residual = 2.30848e-05, Final residual = 9.23408e-13, No Iterations 18 GAMG: Solving for p_rgh, Initial residual = 2.16917e-06, Final residual = 6.50879e-13, No Iterations 13 GAMG: Solving for p_rgh, Initial residual = 2.36853e-07, Final residual = 9.31239e-13, No Iterations 11 GAMG: Solving for p_rgh, Initial residual = 1.9956e-08, Final residual = 7.22653e-13, No Iterations 8 time step continuity errors : sum local = 5.01315e-16, global = -7.7352e-17, cumulative = -1.28489e-15 GAMG: Solving for p_rgh, Initial residual = 8.72431e-07, Final residual = 9.6311e-13, No Iterations 12 GAMG: Solving for p_rgh, Initial residual = 5.31826e-08, Final residual = 8.48754e-13, No Iterations 9 GAMG: Solving for p_rgh, Initial residual = 5.95305e-09, Final residual = 7.37499e-13, No Iterations 7 GAMG: Solving for p_rgh, Initial residual = 5.83901e-10, Final residual = 6.19992e-13, No Iterations 4 time step continuity errors : sum local = 4.301e-16, global = -2.95754e-17, cumulative = -1.31446e-15 ExecutionTime = 905.95 s ClockTime = 911 s Courant Number mean: 0.00122961 max: 0.218001 Interface Courant Number mean: 8.42295e-05 max: 0.113623 Time = 0.4055 MULES: Solving for alpha1 Phase-1 volume fraction = 0.884501 Min(alpha1) = -0.00108301 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.8845 Min(alpha1) = -0.00113319 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.8845 Min(alpha1) = -0.00118055 Max(alpha1) = 1 Relaxing time: 0.04 s DILUPBiCG: Solving for Ux, Initial residual = 0.000458296, Final residual = 1.93453e-14, No Iterations 4 DILUPBiCG: Solving for Uy, Initial residual = 0.000708513, Final residual = 3.09945e-14, No Iterations 4 DILUPBiCG: Solving for Uz, Initial residual = 0.000680929, Final residual = 2.04159e-13, No Iterations 4 GAMG: Solving for p_rgh, Initial residual = 0.00145775, Final residual = 7.57413e-13, No Iterations 105 GAMG: Solving for p_rgh, Initial residual = 0.000112549, Final residual = 7.91032e-13, No Iterations 86 GAMG: Solving for p_rgh, Initial residual = 1.2736e-05, Final residual = 8.64368e-13, No Iterations 87 GAMG: Solving for p_rgh, Initial residual = 1.70598e-06, Final residual = 8.5032e-13, No Iterations 73 time step continuity errors : sum local = 5.88191e-16, global = -9.4146e-17, cumulative = -1.40861e-15 GAMG: Solving for p_rgh, Initial residual = 4.04471e-05, Final residual = 7.85174e-13, No Iterations 86 GAMG: Solving for p_rgh, Initial residual = 6.2229e-06, Final residual = 8.98764e-13, No Iterations 82 GAMG: Solving for p_rgh, Initial residual = 7.91941e-07, Final residual = 9.64218e-13, No Iterations 70 GAMG: Solving for p_rgh, Initial residual = 1.15067e-07, Final residual = 8.55931e-13, No Iterations 60 time step continuity errors : sum local = 5.92062e-16, global = 8.55776e-17, cumulative = -1.32303e-15 GAMG: Solving for p_rgh, Initial residual = 6.83839e-07, Final residual = 8.45255e-13, No Iterations 70 GAMG: Solving for p_rgh, Initial residual = 7.13413e-08, Final residual = 9.04201e-13, No Iterations 52 GAMG: Solving for p_rgh, Initial residual = 3.75992e-09, Final residual = 8.70047e-13, No Iterations 23 GAMG: Solving for p_rgh, Initial residual = 5.88567e-10, Final residual = 8.6016e-13, No Iterations 29 time step continuity errors : sum local = 5.94978e-16, global = -4.85994e-17, cumulative = -1.37163e-15 ExecutionTime = 908.83 s ClockTime = 914 s Courant Number mean: 0.00122992 max: 0.21805 Interface Courant Number mean: 8.40171e-05 max: 0.113785 Time = 0.406 MULES: Solving for alpha1 Phase-1 volume fraction = 0.884499 Min(alpha1) = -0.00123552 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.884499 Min(alpha1) = -0.00128781 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.884499 Min(alpha1) = -0.00133746 Max(alpha1) = 1 Relaxing time: 0.04 s DILUPBiCG: Solving for Ux, Initial residual = 0.000459398, Final residual = 1.06474e-14, No Iterations 4 DILUPBiCG: Solving for Uy, Initial residual = 0.000707475, Final residual = 2.65673e-14, No Iterations 4 DILUPBiCG: Solving for Uz, Initial residual = 0.00125732, Final residual = 1.15904e-13, No Iterations 4 [3] #0 Foam::error:rintStack(Foam::Ostream&) in "/home/david/OpenFOAM/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [3] #1 Foam::sigFpe::sigHandler(int) in "/home/david/OpenFOAM/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [3] #2 in "/lib/x86_64-linux-gnu/libc.so.6" [3] #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/home/david/OpenFOAM/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [3] #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/home/david/OpenFOAM/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [3] #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/david/OpenFOAM/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [3] #6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) in "/home/david/OpenFOAM/openfoam221/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" [3] #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/home/david/OpenFOAM/david-2.2.1/platforms/linux64GccDPOpt/bin/waveFoam" [3] #8 [3] in "/home/david/OpenFOAM/david-2.2.1/platforms/linux64GccDPOpt/bin/waveFoam" [3] #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [3] #10 [3] in "/home/david/OpenFOAM/david-2.2.1/platforms/linux64GccDPOpt/bin/waveFoam" Thanks ! David |
October 22, 2015, 07:57 |
Camille Bilger
Rep Power: 12 |
Hi David,
Did you solve your issue? |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 91 | December 21, 2022 04:50 |
Foam::error::printStack | 1988 | OpenFOAM Running, Solving & CFD | 2 | April 18, 2014 05:36 |
[surface handling] SurfaceFeatureExtract Foam::error::printStack | donQi | OpenFOAM Meshing & Mesh Conversion | 1 | August 15, 2013 00:43 |
#0 Foam::error::printStack (MotorBike tutorial) | GPan1 | OpenFOAM Running, Solving & CFD | 0 | November 4, 2012 04:48 |
blockMesh with Foam::error::printStack | sontac | OpenFOAM | 1 | February 22, 2012 03:32 |
