Cs in the homogeneousDynSmagorinsky LES model |
August 3, 2015, 23:00 |
ALLEN
Rep Power: 11 |
Hello, foamers
Recently I want to use the dynamic Smagorinsky model for my LES simulation on a incompressible channel flow over a wavy bottom (like a sine-shaped hill), with horizontal planes being cyclic. I am a freshman using turbulence models, even conceptually not clear about that. In openfoam, it is homogeneousDynSmagorinsky. But I have read a thread (actually quite long) talking about different models, it is quite confusing because the thread has covered different versions of foam. 1. So the first question is: in OpenFOAM2.3.0, the homogeneousDynSmagorinsky still calculate the Cs coefficient globally(based on the averaging of the whole computational domain)? or it now can account Cs locally? 2. I found there is a modified model proposed and uploaded by @alberto: See: Improved implementation of dynamic Smagorinsky where @alberto claimed that it can calculate the Cs locally. I want to know how does it work? have some one tried that? 3. I read Eugene's thesis, where he used oneEqEddy model and claimed that the dynSmagorinsky model will not deliver good performance around the wall boundaries which is important in my study. But I recently read a paper by Yang&Shen(2013), they actually uses dynamic Smagorinsky model for a wavy-bottom channel flow with high Re_tao=4096. So, can someone give some opinion on that? I want to perform LES with both models at a low Re_tao and compare the results with DNS results. 4.Has someone got a tutorial using dynSmagorinsky model? like the numerical setup especially the wall function and the initial conditions. I think a tutorial would be of great use for beginners like me. Thanks, any comment or suggestion would be quite really helpful. Last edited by allenfieldin; August 4, 2015 at 08:30. |
August 4, 2015, 23:10 |
ALLEN
Rep Power: 11 |
Oops, nobody comments on this, heart break
LES Filter in Smagorinsky model on inhomogenous grids | Ivan | Main CFD Forum | 1 | October 25, 2012 11:30 |
Implementation of wall model to LES | saeedi | Main CFD Forum | 3 | August 24, 2012 14:51 |
documentation of LES model: oneeqeddy | MacGyver | OpenFOAM Running, Solving & CFD | 1 | July 16, 2012 09:09 |
Uregent LES model | ck3 | FLUENT | 6 | June 4, 2012 23:30 |
Implementing a new LES Model in OpenFoam | fs82 | OpenFOAM | 6 | October 13, 2009 09:58 |
