Stationary hydraulic jump - interFoam
Old   September 6, 2015, 12:40
Question Stationary hydraulic jump - interFoam
GiuliaB
Bessy is on a distinguished road
Dear Foamers,
I've started to work with OpenFOAM recently in order to simulate an hydraulic jump with the interFoam solver in laminar flow (as first step).
The characteristics of the "riverbed" (rectangular section) are:
i = 0.001
B = 5 m
L = 50 m .
Creating the mesh, I divided inlet and outlet in two segments, one where I should have water and one where there should be air (as I saw it was suggested inside this forum), so the inlet height of the water is 0.1 m.
My BC are the following:
U
inlet_water
type fixedValue;
value uniform (2 0 0);
inlet_air
type fixedValue;
value uniform (0 0 0);
outlet_water
type fixedValue;
value uniform (0.83 0 0); //calculated in order to obtain the height of the water expected
outlet_air
type fixedValue;
lowerWall
type fixedValue;
atmosphere
type pressureInletOutletVelocity;
p
inlet_air
type zeroGradient;
inlet_water
type zeroGradient;
outlet_air
type fixedFluxPressure;
value uniform 0;
outlet_water
value uniform 0;
lowerWall
type zeroGradient;
atmosphere
type totalPressure;
p0 uniform 0;
U U;
phi phi;
rho rho;
psi none;
gamma 1;
value uniform 0;
alpha
inlet_air
type fixedValue;
value uniform 0;
inlet_water
type fixedValue;
value uniform 1;
outlet_air
type inletOutlet;
inletValue uniform 0;
value uniform 0;
outlet_water
type inletOutlet;
value uniform 0;
lowerWall
type zeroGradient;
atmosphere
type inletOutlet;
value uniform 0;
With this setting I obtain an hydraulic jump that is not stationary, indeed the hydraulic jump is pushed from downstream to upstream (please see the video of the simulation here).
I think that the problem is due to the outlet BC of the pressure. I tried also to set a different fixed value for the pressure in outlet, the one that should lead to the equilibrium between the slow and the rapid flows, but nothing changed. It seems that the software doesn't maintain my BC in outlet while doing the simulation.
Do you have any suggestion for obtaining the stationary hydraulic jump?
Thanks in advance.
Bessy is offline   Reply With Quote
boundary condition p, hydraulic jump, interfoam, outlet boundary condition
Hydraulic jump The King OpenFOAM 5 June 18, 2023 07:55
Problem modeling hydraulic jump in an open channel with interFoam (VoF) arnau1985 OpenFOAM Running, Solving & CFD 12 December 26, 2022 05:54
How to form hydraulic jump at specified location mojtabaivi FLOW-3D 5 August 13, 2015 04:22
Weird hydraulic jump with interFoam [SST k-omega] keepfit OpenFOAM Running, Solving & CFD 6 March 23, 2015 12:55
interFoam | Hydraulic Jump | Correct boundary condition p_rgh pythag0ra5 OpenFOAM Running, Solving & CFD 17 September 5, 2014 04:31
