August 10, 2015, 05:59 |
Unknown function type loadPsiThermoModel
Ehsan
Rep Power: 26 |
when run the code, an error on loadPsiThermoModel occurs as this:
Starting time loop [0] [0] [0] --> FOAM FATAL ERROR: [0] Unknown function type loadPsiThermoModel Valid functions are : 56 ( CourantNo DESModelRegions Lambda2 Peclet Q abort addForeignMeshes addGlobalVariable blendingFactor calculateGlobalVariables cellSource clearExpressionField coded createSampledSet createSampledSurface dsmcFields expressionField faceSource fieldAverage fieldCoordinateSystemTransform fieldMinMax fieldValueDelta foreignMeshesFollowTime initSwakFunctionObject manipulateField manipulatePatchField nearWallFields partialWrite patchProbes pressureTools probes processorField readFields regionSizeDistribution removeGlobalVariable removeRegisteredObject residuals scalarTransport setTimeStep sets solveLaplacianPDE solveTransportPDE solverPerformanceToGlobalVariables streamLine surfaceInterpolateFields surfaces swakCoded timeActivatedFileUpdate turbulenceFields vorticity wallBoundedStreamLine wallShearStress writeDictionary writeRegisteredObject yPlusLES yPlusRAS ) [0] [0] [0] From function functionObject::New(const word& name, const Time&, const dictionary&) [0] in file db/functionObjects/functionObject/functionObject.C[1] [1] [1] --> FOAM FATAL ERROR: [1] Unknown function type loadPsiThermoModel Valid functions are : Code:
loadThermo { type loadPsiThermoModel; correctModel false;//I think that if "correctModel" is set to "true", it will call "thermo.correct()" at the beginning of each time iteration. // correctModel true; allowReload false;//it's possibly for keeping track of the changes in "constant/thermo*" failIfModelTypeExists false; outputControlMode timeStep; outputInterval 1; } thanks so much for helping.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. |
June 9, 2017, 07:50 |
Mohamed Elghorab
Rep Power: 9 |
I know it's from long time but I got the same problem with the vorticity and gradU in openfoam-1612+ did you find the solution for that problem Crazzy.Pirate43 |
Inlet patch problems | martyn88 | OpenFOAM Running, Solving & CFD | 6 | April 21, 2017 18:34 |
[Commercial meshers] converting Fluent mesh to openfoam standard mesh | deepesh | OpenFOAM Meshing & Mesh Conversion | 31 | March 29, 2017 05:59 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
Elements that limit the Courant number | skabilan | OpenFOAM Running, Solving & CFD | 9 | July 3, 2008 12:07 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
