Does sliding mesh in OpenFOAM supports the 3 rotation along three perpendicular axis
Old   August 15, 2015, 03:25
Question Does sliding mesh in OpenFOAM supports the 3 rotation along three perpendicular axis
sagar gurnani
sagarg is on a distinguished road
Hi Foamers,
I want to do study aerodynamics of aircraft using 3 degree of freedom i.e. by allowing the aircraft to rotate along the three axis and based upon the DFBI solver I will change the relative inlet velocity and based on the aerodynamic relation I will trace the trajectory of aircraft. I would like to know whether it is possible to obtain 3 rotational degree of freedom using sliding mesh in OpenFOAM and how to do it??
I am new to OpenFOAM please suggest me.
Thanks
sagarg is offline   Reply With Quote
Polyhedra and sliding mesh? rockewan FLUENT 5 December 1, 2018 19:07
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 11:14
[Other] vtk mesh or Abaqus mesh to OpenFOAM bigphil OpenFOAM Meshing & Mesh Conversion 27 November 23, 2015 17:31
[Other] dynamic Mesh with angular velocity not parallel to x axis donQi OpenFOAM Meshing & Mesh Conversion 5 October 2, 2014 23:19
ICEM extrude mesh by rotation derkaiser ANSYS 0 December 21, 2009 05:01
